Question about Vtech Lands Phones
Is it possible to block phone numbers on VTECH 6531-3? If so, how do I unblock them?
6ya staff
SOURCE:
Bajanguru
Sylvester Brathwaite
  • 7752 Answers
SOURCE: UNBLOCKING A NUMBER
*2767*3855# press that
Posted on Oct 25, 2008
Anonymous
  • 11 Answers
SOURCE: HOW DO I UNBLOCK A BLOCKED PHONE NUMBER
Go to: MENU press: # Enter direct No. :217 Search number then Erase or Edit
Posted on Jul 12, 2009
Anonymous
  • 9 Answers
SOURCE: How would I unblock a number that has been blocked
try going to the menu and search for anything related to blocking numbers. and select it and it should have a list of numbers youve blocked, and you should be able to delete them.
Posted on Jul 18, 2009
Anonymous
SOURCE: kx-TGA641T how does one unblock blocked number
http://ww2.justanswer.com/uploads/MCVGreg/2009-09-21_023145_KXTG9331-Remove-Blocked.pdf
Viewing/editing/erasing block call
numbers
1 {MENU} -> {#}{2}{1}{7}
2 {V}/{^}: Select the desired item.
~To exit, press {OFF}.
3 Proceed with the desired operation.
■ Erasing a number from blocked list:
{Erase} -> {Yes} -> {OFF}
you can also edit:
■ Editing a number:
{Edit} -> Edit the phone
number. -> {Save} ->{OFF}
Posted on Feb 28, 2010
heysukisuki
SOURCE: I accidentally blocked my cell
Do the following:
Select MENU
Select INITIAL SETTINGS
Select CALL BLOCK
Find and ERASE the number you want to remove the block from.
Posted on Feb 12, 2011
How to unblock a number on vtech cordless phone
see these links
Product Support ' VTech® Cordless Phones
https://www.vtechphones.com/support/technical-support/product/3394
Press VOLUME? until you see Call Block, then press MENU/SELECT. Press VOLUME? until you see Calls w/o num, then press MENU/SELECT. Press VOLUME? until you see Block, then press MENU/SELECT. All calls without a phone number will be blocked.
How to unblock a number on your VTech cordless phone - Fixya
www.fixya.com/support/t26508052-unblock_number_vtech_cordless_phone Mar 4, 2017 - my vtech 5.8 GHz disconnects while I am talking~replaced batteries and charges the phones for 24 hours. I cold talk 10 minutes during this time ... How can I unblock a number on my vetch phone. It ...
Mar. 11, 2018
SOLVED: How to unblock a Vtech cordless phone ...
Sep. 12, 2017
How do i unblock numbers from a vtech phone ...
Jan. 19, 2015
Vtech DECT 6.0 Digital Cordless Phone Unblock ...
Aug. 3, 2014
More results from www.fixya.com
unblock number on vtech cordless phone Google Search
Jun 11, 2018 | Vtech Lands Phones
How do I unblock a number on my vtech cordless phone
Apr 19, 2018 | Vtech Lands Phones
How to unblock a Vtech cordless phone with blocked caller the model number is:CS6919
With the handset in standby mode, press Menu (on the right below the LCD screen). Use the Up/Down arrows to navigate to Call Block. Press Select (the same as Menu). Navigate with the Up/Down arrows to highlight the line Block List and press Select again. Navigate to the line Review with the Up/Down arrows and press Select. Use the Up/Down arrows to navigate to the blocked number that you wish to delete. Press the Mute/Delete button (the center button below 0). You should hear a confirmation tone and either the next number in the block list or list empty should appear on the LCD screen. (You can't delete the entire list at once.)
The procedure to delete a blocked item in the Call Block list is given on page 21 of the full manual. The manual is available from VTech on the product page: https://www.vtechphones.com/store/pd/3370/CS6919-Cordless-Phone-with-Caller-ID-Call-Waiting . The direct link to the manual is https://cdn-media.vtechphones.com/products/CS/CS6919/CS6919-X_WEBCIB_V4_20160224.pdf .
I hope this helps.
Sep 12, 2017 | Vtech Lands Phones
I would like to unblock a number 352 428 4215
A make and model of phone would help? We can't do it, you have to do it yourself.
Steps to block a number on your iPhone 6.
  1. From the home screen, tap the Phone icon.
  2. Tap the Recents icon.
  3. Scroll to the preferred contact and tap the Info icon.
  4. Scroll to and tap Block this Caller.
  5. Tap Block Contact.
How to Block or Unblock a Number on your iPhone 6 - Sprint Support
https://support.sprint.com/...Unblock-a-Number.../WHowToSetupGuide_542_GKB8146... Feedback
About this result
Block or unblock contacts on your iPhone or iPad ' Vodafone Support
vodafone.intelliresponse.com/index.jsp?id=1911...Block...unblock... Block on iPhone. Make sure you've saved the phone number and/or email address as a contact first. Block on iPad. Make sure you've saved the phone number and/or email address as a contact first. Unblock on iPhone. Open the 'Phone' app. Unblock on iPad. Open settings and tap 'Messages', or 'FaceTime', and then 'Blocked'.
how to unblock a contact on android - AndroidFact
androidfact.com/how-to-unblock-a-contact-on-android/ Jun 15, 2016 - If it turns out the number you are trying to unblock is not in your contact list you will have to head on over to the call log and find the number you ... unblock number Google Search
Jan 17, 2017 | Cell Phones
I need to block a couple callers from calling whats the number to block # what
Call youre service provider and then you can block all outgoing calls with a code they give you. to unblock phone pick up phone put code in and make youre call.
Jan 19, 2015 | Vtech Lands Phones
WIFE`S CELL PHONE # IS BLOCKED, BUT IS NOT IN BLOCKED #S
Have her dial *82 before she dials the home number. If that works she has the cell phone set to block her number. *82 should unblock it for just that one call.
Aug 25, 2014 | Asavings Panasonic KX-TGEA20S Dect 6.0 1...
Www panasonic ca
How can i transfer directly all infos (contacts etc...) from my old KX-TG7431C to my new KX-TG4033C?
Apr 27, 2013 | Vtech Digital Cordless Telephone VT-2568
I need to unblock a number
You can check the call black list, if number is in black list please remove it.
Apr 05, 2012 | Vtech DECT 6.0 Digital Cordless Phone
How do i block someone from calling?
you need to call your service provider, and ask them to block the number that you want.
you can block your number, press *67, nobody can see your number
to unblock your number *82
May 13, 2010 | Vtech CS5121 Cordless Phone
Lands Phones Logo
49 people viewed this question
Top Vtech Lands Phones Experts
Marvin
Marvin
Ekse
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
