Question about Boating
My elite 5 sonar/gps keep flashing 2.0 will not show actual depty
  • Boating Master
  • 1,598 Answers
From other forums, the transducer seems to be a problem if it isn't pointing directly down when the boat is in the water.
Posted on Jul 03, 2019
2 Suggested Answers
6ya staff
SOURCE:
Mattisson
SOURCE: Lms 520c 5" Screen Color External Gps And 200 Khz Sonar System: I have a Lowrance LMS 520C on my boat. The GPS wi...
I have the same problem on my 520C.
I have no solution but I hope you have find some?
Best regards
Dan
Posted on Oct 31, 2010
Works on down scan but not on sonar
Hummingbird systems have the ability to turn off pages so they will not be displayed. On your main menu look for the "views" tab. Scroll down to the sonar view page and see if it shows visible or hidden by that page. If it says hidden, select visible and you should be all set.
Oct 01, 2014 | Humminbird 1158c Di Fishfinder With...
How do i find water depth
Water depth should show automatically on your sonar page.
if it does not then either you have selected "stop sonar" under your sonar options or you have opted to turn off the depth displayou so the numbers don't show up.
if you areally viewing your GPS or split screen sonar/GPS page, sometimes the depth display is not visible on these pages unless you specifically instruct the unit to display it.
Lowrance HDS 5 Gen2 Fishfinder GPS Chartplotter
Here is a link to Lowrance where you can download a pic version of the operators manual.
Go to page 11 "overlay data" this will give you a step by step of how to add data or readouts to different screens.
Aug 27, 2014 | Lowrance HDS 5 Fishfinder GPS Chart...
Flashing screen
two things can be taking place 1 you have a bad key pad 2 you have a bad transducer(short in wire )
Oct 22, 2013 | Lowrance Lms 520c 5" Screen Color External...
The GPS component of my Lowrance Elite-5 Gold is malfunctioning about 50% of the time.
Hey Les, Since you have replace both the unit and transducer, you have eliminated/diagnosed most of your problem.. Its in the wiring... sometime when I am in full GPS mode I get erroneous depth readings..?? Have you tried a different GPS module (the "puck")?
https://www.lowrance.com/Root/Lowrance-Documents/US/ELITE-5-7_HDI_OM_EN_988-10647-001_w.pdf
Apr 22, 2017 | Lowrance ELITE 5 GOLD COMBO
Lowrance HDS 5 Sonar faulty
You realise we are FIXYA, we are not Lowrance?
Is this when you are moving, or when you are stationary? If it is stationary, then the transducer or the wiring to it, or the plug into the head is faulty.
If it is only when you are moving, the transducer is not sitting at the correct angle and you are getting a disrupted water flow over it.
The other possibility is that you have the sensitivity set too high, which shows more activity on the screen. Set the head back to Defaults.
Feb 11, 2018 | Lowrance Hds-5 GPS Receiver
Best regards
Dan
May 07, 2010 | Lowrance Lms 520c 5" Screen Color External...
Hello- My 332c will not show speed. It worked before.The spinner wheel is not damaged.Speed just flashes 0.00 mph Thanks, Jeff
Try setting up the speed in the overlay data menu again:
1. Press MENU, arrow down to OVERLAY DATA and press ENT
2. Highlight the option for speed (WATER SPEED or GROUND SPEED) and press ENT
3. Highlight the REMOVE button and press ENT
4. Highlight (PRESS ENT TO ADD) and press ENT
5. Arrow down to SONAR DATA and press ENT
6. Arrow down to WATER SPEED and press ENT, a check will be displayed in the box
7. Press EXIT twice
If the speed is still flashing, the data is still invalid. Try resetting the unit completely:
1. Turn unit off
2. Press and hold the PAGES and POWER key until the "DO NOT RELY..." alarm appears
3. Set up the overlay data for speed again: 1. Press MENU, arrow down to OVERLAY DATA and press ENT; 2. Highlight (PRESS ENT TO ADD) and press ENT; 3. Arrow down to SONAR DATA and press ENT; 4. Arrow down to WATER SPEED and press ENT, a check will be displayed in the box; 5. Press EXIT twice
If the speed is still flashing, good chance the speed sensor is bad even though the wheel still spins. Install the latest LMS-332 updates from http://www.lowrance.com/en/Products/Marine/Full-Size-SonarGPS-Chartplotter-Combos/LMS-332C/Downloads/LMS-332C-Software-Update/ and set up the overlay data again.
If it turns out that the speed sensor is bad, just use speed from the GPS. This can be set up from the overlay data menu as GROUND SPEED.
(note: the overlay data must be set up for each page individually. So if you set up speed to be displayed on the map screen, it will not also be set up on the sonar page)
Jul 12, 2009 | Lowrance LMS-332C GPS Receiver
Boating Logo
57 people viewed this question
Top Boating Experts
ray gallant
ray gallant
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Boating Expert? Answer questions, earn points and help others
