HELP! I got this camera about a month ago and now I am getting lines on the LCD display, occasional file errors and sometimes the lens won't even open all the way :(
Sounds like 2 things, unformatted SD card and carbon based alkaline batteries. If using SD card, you MUST FORMAT the card upon first use and then occasionally there after. This model camera cannot use an SD card bigger than 1GB, so make sure you aren't using a 2GB or higher. Also, make sure you stay away from alkaline batteries, you will waste your money. Try using Energizer Lithium or Duracell Power Pix, you will get your moneys worth.
