RCA RT2500 System Logo
Posted on Aug 16, 2009
RCA RT2500 will not turn on
RCA RT2500 has a red iluminated power button but will not turn on.
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Sep 28, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1153
Points
10
Press and hold power button while unplugging and plugging power supply cord may take a few tries worked for me
  • David Jr
    David Jr Aug 08, 2021
    Rt2500. Worked like a charm. I unplugged it. Held the power button. While still holding the power button I plugged it back in. Powered right up. Ty.
Set won't turn on. Was working fine last evening. Now nothing.
Reciever RCA RT2500 ' Techlore
www.techlore.com/forum/thread/11889/reciever-rca-rt2500
Aug 20, 2005 - 31 posts - ‎23 authors
hey ive got the rca RT2500 home theater system. .... won't power up) regardless of number of times I try to simulate a 120 V power flash (pulling plug .... My RCA receiverturns on but there is no sound...what can this mean?
Trouble getting sound from home theatre system with my ...
www.tomsguide.com/.../trouble-sound-home-theatre-system-appreciated....
Mar 27, 2013 - TV: Sony Bravia KDL-60EX645 Home Theatre System:RCA RT2906 ...-I've set the television, per the manual's instruction, to "Audio System" and "Audio Out: Fixed." This should allow the TV to turn off its internal speakers and switch .... SolvedI have F & D home theatre system, my rear speakers won't work.
Problems connecting surround sound to LCD TV... - Forums - CNET
www.cnet.com > Forums > TVs & Home Theaters
CNETJul 30, 2006 - Hey I have a 26" LCD TV from Polaroid and a Philips DVD home theatersystem. ... the Audio setup on the tv and TELL it to output the sound via the RCAcables ... However, you would normally turn off the TV speakers with a menu ... I just can't figure out why the TV audio won't play on the surround sound. Anynet+ - Home theater won't turn on with tv
Jun 11, 2015
TV won't turn on
Jun 10, 2015
Audio Return Channel Problem
Aug 23, 2011
rca tv no sound?????
Jan 1, 2006
More results from www.cnet.com
1helpful
My rca rt2500 turns of after thirty minutes of playing
Sound that the power supply section has the fault. Seek tech support.
Lost my remote for my RCA RT2500 Audio/Video Receiver and i cant turn it on because the power button is stuck on standby. I purchased another remote model CRK76 but it wont turn unit on. I also unplugged...
You need to confirm if the power switch is working as the button is stuck . So it is best to get this part corrected before we move to the remote as the power switch or the button aligment can be corrected if you open to check the continuity.
Next the remote controller must be checked for the IR outputs. please check this link below for tips to repair or find a link for a universal type remote.
http://www.fixya.com/support/r6178946-tips_repair_remote_controller
http://www.espares.co.uk/search/remote-controls/p/1090
3helpful
13helpful
3answers
I have an RCA RT2500 audio-video surround sound receiver about 10 years old. For the second time in its life, a power fluctuation has knocked it out of service. The standby light comes on, but no power to...
Hold down the power button and unplug the unit. Now release the power button. Plug the unit back into the wall. Now press the button. The system should power up.
10helpful
2answers
Model RT2500/ RT 2500R. Standby button is lit but when I press it the home theater fails to turn on
I had the same problem. I held down the power button while plugging the unit into the wall and it fired right up. works fine now. You might have to do this a couple of times but mine was fixed on the first try.
My model is the RT2500
RCA RT2500 audio amplifier will not turn on when I push the on button. I reset all the plugs inside and checked visually the fuses they seem ok. Would like to know if there is a reset jumper on the board...
Verify 120v at wall socket. Plug 2250 into mains, if not so already.
QUICKLY unplug and plug back in the unit. That should put the unit into DEMO mode, at which point you can press the (now red) power button and the unit should function nominally.
Power cord for a rt 2500
Sandworms, that is the exact problem I had after a power out. It doesn't look the same as ducast's problem though. I posted the same solution in another thread. Here's hoping it works for you too.
When the red LED on the power button would glow, but it wouldn't turn on. Try unplugging it and plugging it back in repeatedly and it will eventually turn on. If that doesn't work try moving it to another outlet then try plugging it back in and out.
Static kinda sound
hi sounds like a earthing problem in the reciver or problem in the speakers try rotaiting the speakers back to front front to back left to right ETC.. good luck
Top RCA Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
