Bolens BL160 25 cc weedeater
SOURCE: blowing gas out the air intake
Eight years is great for a weedeater! Blowing out can mean something is stuck in the reed valves, or one may be broken. They are just under the carb, usually. Be real careful with the gaskets. If you mess up any, silicone will do. Use good car gasket silicone.
SOURCE: weedeater carburator setting on bolens 31cc
initial setting is 1and1/4 turns out for walbro carb.
1 turn out zama carb.
SOURCE: craftsman 28cc gas weedeater gas line connections
The longest, and sometimes smaller in diameter of the two fuel lines, goes from
the carburetor to the bottom of the tank. Leave enough slack in this
line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The
other
fuel line goes from the primer bulb to just inside the tank,
(about an inch). make sure that you get the right size fuel lines. The
plastic coupling goes on the end of this line, inside the tank. This
keeps the line from pulling out of the tank.
(HINT): When feeding the lines through the tank holes, cut the lines at an
angle. They will feed much easier into the holes. You can than cut them
off square, once you know that you have enough to work with.
If you need further assistance, just let me know.
Jim
SOURCE: on weedeater blower and vac gas line is broke from
Yes if your asking about the fuel line yes it hooks to the filter out thru the wall of the gas tank straight into the carb. if it broke out side the tank you can try a smaller plastic hose to stick inside to reconnect the two parts. if it broke inside the tank try to replace as one hose.
