If your printer has the wifi blue symbol on control panel, press that and notice the list of different choices.
The easiest is "WPS", but this means your router must have a "WPS" switch.
if it does then the rest is easy.
On your printer begin again press WIFI button.
scroll until WPS is available, PRESS "WPS".
instructions should appear to press ,on your router, the WPS button (i hold this button for two seconds then release)
return to your printer, panel after awhile should say connected.
to test find email then on your device select print, the Brother printer name should appear. Select then print.
Later even if your printer goes to sleep it will awaken on the print command , a little slower, and complete print request.
SOURCE: do i need to use usb lead to install wifi on labtop use brother dcp j125
On most wifi printers, you need a USB cable to set it up the first time.
SOURCE: How to fix brother printer won't connect to wifi?
I have brother smart wifi printer and it keep disconnecting from wifi. Its connected and ince i gave command for print it won't print. I was very frustated. One of my friend advice me to search answer on http://www.fixotip.com/brother-printer-wont-connect-wifi/
and i fixed my printer by myself.Check out great article for Why Is My Brother Printer Wont Connect To Wifi Fixotip
