Garden Logo
stick head Posted on Jun 30, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why does Simplicity Sunstar turn over but not catch?
Simplicity Sunstar 20 hp hydro, with 60" mower deck. It turns over but won't catch. Plenty of gas. pto switch is off. foot firmly on brake pedals. seat switch had been disabled by previous owner. this lawn tractor has run fine before for us. it has a Kohler Magnum 20 motor, 2 cylinders. When I turn the key, something is turning but it doesn't sound like the tractor does normally. Any ideas? Thanks. -J
Wayne McNeil
Level 2:
Novelist:
  • Expert 209 Answers
  • Posted on Jun 30, 2019
Wayne McNeil
Expert
Level 2:
Novelist:
Answers
209
Questions
Helped
116740
Points
421
If it's a Briggs motor its possibility the little electric solenoid on the very bottom of the carburetor isnt opening when the key is turned. Put a spoonful of gas in the plug hole Nd if it catches then dies then it's a fuel related problem
  • 1 more comment
  •  stick head
    stick head Jul 08, 2019
    it's a Kohler Magnum 20 motor, 2 cylinders
  • Wayne McNeil Jul 09, 2019
    Do the same for that engine also. If it starts then fuel delivery is the problem
  •  stick head
    stick head Jul 09, 2019
    ok I'll try that. thanks.
FastHarley
Level 3:
  • Master 761 Answers
  • Posted on Jul 01, 2019
FastHarley
Master
Level 3:
Answers
761
Questions
Helped
360447
Points
2528
Remove fuel line and see if there’s flow. Sounds like a fuel issue. Also check spark.
If you’ve found this helpful, please click the green “helpful” icon. If you have 20 seconds please leave a few words as a review or recommendation! Also, follow me for more answers to everyday issues, I’m all for saving you money and making the most of your time! Thanks and have a great day!
Testimonial: "Replaced fuel filter. The carb side was bone dry and the tank side had gas. Still no start but I may need to dribble a little gas into the intake to get it to start to catch."
john h
Level 3:
Top Expert:
  • HP Master 29,494 Answers
john h
HP Master
Level 3:
Top Expert:
Answers
29494
Questions
0
Helped
7559424
Points
193449
Mat need tune up -carb work -clean rebuild replace --or other safety
5 Related Answers
Anonymous
  • 25 Answers
  • Posted on Jun 23, 2009
SOURCE: simplicity mower stalls when brake released
There is another safety switch connected to the parking/service brake. Check that one too. Sounds like its the one.
Anonymous
  • 127 Answers
  • Posted on Jun 30, 2009
SOURCE: Mower deck will not engage.
you have sheared off the keyway either on the mandrel or pully on the engine
Anonymous
  • Posted on Aug 24, 2009
SOURCE: simplicity sunstar 20hp rear pto won't engage deck
your electric clutch may need adjustment. Take the hood off. Look behind the double pulley that's on the crank shaft. Behind the pulley is an electric clutch. You will need a .010-.015 feeler gage and check between the clutch plates. You will tighten the three screws that mount the clutch to the motor. Try and get as close to .010" as you can. After adjustment start the motor and try and engage the pto. I bet it will work.
Good luck
Anonymous
  • 2702 Answers
  • Posted on May 02, 2010
SOURCE: engine cutting off after engaging the pto (mower deck) JD 317
its likely to be a switch playing you up try hard wireing the switch to see if it stops this cutting out first, do one switch at a time till you fine the one playing up
colesmowers
  • 40 Answers
  • Posted on Jun 04, 2010
SOURCE: My simplicity Coronet Hydro 13 lawn tractor loses
The fluid in the transmission is a multigrade oil. sometimes you can change the oil by removing the transmission partially or entirely and change the oil to a heavier grade like 15W40 or 20W50, the transmission has a vent mechanism on top that is where the oil would be extracted or drained from and then refilled, the level at full cold is 1" to 1 1/4" below the bottom edge of the inside of the vent pipe or plug boss. some of these had a flat vent plug, some have a hose with the vent in the end attached at a nipple and still some older units had a reservoir like on the larger tractors. The reason your trans is slowing is due to wear in the hydraulic pump face.
I am looking for a detailed wiring diagram for a Simplicity zero turn mower model #2691318. Thanks
you might try Simplicity customer service. There are many image files on the web for Simplicity Zero Trun mowers, even 42 inch ones. The problem is that they are not organized by the mower model. https://www.partstree.com/models/2691318-00-simplicity-courier-42-zero-turn-mower-23-gross-hp-briggs-stratton/
--unless the link above makes a liar out of me. maybe the following will also be of help; https://www.caretxdigital.com/
Jul 02, 2023 • Garden
Mower deck slows and stops when I turn my Simplicity riding mower to the left,
HI,
The simplicity has a a two point mounting system for the deck. It attaches to the front axle which has two runners that go to the front axle's rear support bracket.
Closely check the runners near where the pins that hold the mower deck. They are known for cracking and breakage. Secondly, closely check the decks metal center support bracket, it bolts to the center of the deck and supports the idler pulleys as well as the deck alignment and mounting. Those, too, are known to crack near the front just behind the front pulley.
Aug 25, 2012 • Garden
2answers
Belt size for 616 deutz allis riding mower ,deck & drive
most wear parts numbers are on the bottom side of the hood.
Jul 29, 2012 • Garden
I have white zero turn 54" lawn mower. The engine runs but the blades won't turn on. Please any advise will help
This is a belt adjustment problem. You machines belt has either broken, or is loose to the point where it won't engage the blades at all, or has just slipped off the pulley. I believe the belts are on top of the deck covered by removable covers that are bolted to the deck. Check and see. GOOD LUCK.
Top HP Garden Experts
vince
Are you a HP Garden Expert? Answer questions, earn points and help others
