Go into audio set up and change
SOURCE: Apex digital Converter DT502. Have it connected
no signal from Dvd to DT250A digital converter to tv
SOURCE: How to turn off close caption on Orion TV 1934A
Try unplugging your TV while it is on. This will cause the Factory Defaults to restore. When you turn it back on every thing should work normally again
SOURCE: I have a ge rm24914
You can find a list of supported devices codes for your RM24914 and other GE remotes that require a 4 digit code, here. (a list of device codes for use with GE universal remotes that require a 3 digit code can be found here instead). Additionally, the user manual for the RM24914 can be found here. You will need to download a free program called Adobe Reader to view these files.
I hope this helps and good luck. please rate my reply. Thank you.
SOURCE: I have a spare insignia
Usually spare remotes are already programmed to work with the unit already. Especially if the spare remote came with the unit. But if not and the spare remote is not meant for the same model then there is no way to program it to work for your unit. Usually the remotes of products which are the same model work interchangeably with each other.
The particular remote you have was made for LSX300-4DM, NS-DXA1, NS-DXA1-APT, IXV-6472 models which have been discontinued and the remote does not have any provision for programming new devices. But you can try using it direct if it works.
Hope this support has been helpful?
Thank you for visiting FixYa.
SOURCE: can i use a dishnetwork
Yes you can. try to go automatic search or code search, look on the manual book.
