I installed Microsoft Digital Image Suite 2006 on Windows 10 Pro 64 bit using a work around. The program appears to be working without any issues until I downloaded some additional fonts and installed them. When I attempt to change text to the newly downloaded font I am able to see and choose the font, however, the text appears to disappear and I can not see anything. Has anyone else had this issue? Does anyone know of a fix for this issue? Thank you
Follow the steps to contact Yahoo mail service:
SOURCE: Font size and yahoo games
Typically, to adjust the font size within a browser, you would press command and the "+" plus key to increase the font size within the browser. You can also access it through the top menu bar by going to "View" then down to "Text Size" and doing that until you're satisfied.
SOURCE: ECS 945GCT-M/1333 System Board
I can see you getting an error with pci.sys but not with pcy.sys.
Did a full system scan in a working WinXP Pro & found not such animal within the system or regestry. After looking through microsoft I did come across pci.sys and what may creat such an error. I would point to your onboard VGA. If intergrated into the board as I suspect. It is a pci device. During install windows found something wrong with it hence your error & blue screen. Suggest using your PCIE card & set bios to same disabling the VGA. Your install should no longer fail.
Good luck & please vote!
SOURCE: Sony Handycam DCR-HC42 Mini DV not recognized by Windows 7
win vista and win 7doesn't support usb streaming. the usb driver for this model would not be compatible with your computer's OS. although, you were able to download PMB still this wouldn't work, it's basically an alternative software that you can use with the newer OS. still the device driver would not be installed. and you would get a message that "ilink connection is not detected". the reason you get that is bec the camcorder and the software is intended for use with the dv (ilink or ieee1394) connection. so if your computer has an ieee1394 card and you have a compatible ilink cable,then your good to go,it should be a plug-and-play connection (no drivers required). all you need then would be a video capturing software (like win moviemaker) to transfer videos from tape to PC. hope this helps. thanks :)
SOURCE: D-link DU-562m does not work with windows 7 RC Ultimate 64 bits
Download from the following site.
http://load2.file-drivers.com/download.php?id=87889
SOURCE: I have Windows 7 64 bit and I cannot get my canon
There is solutions to getting the Canon MF 3111 to work with Windows 7 64bit on this site here: http://www.dragonblogger.com/canon-mf3110-printing-with-windows-7-64-bit/ check the article and comments for help.
