SOURCE: operating manual for Honda whipper snipper
If you have the UMK 425 model....
http://campaigns.hondampe.com.au/Power%20Equipment/ownersmanuals/brushcutter/umk425own01.pdf
SOURCE: my fs 45 whipper snipper is starting but running
I have a Stihl FS 45 and have had problems with it running for a short time then cutting out. The problem is like to be either- the filter attached to end end of the fuel pick hose that goes down into the fuel tank is blocked or- there is a crackor split in the corrugated section of the fuel pick up hose between the fuel tank and the carburettor. If such a crack or split exists it will cause air to be sucked in with the fuel upsetting the fuel/air ratio. A new hose not adjustment is the only cure
SOURCE: homelite whipper snipper is hard to start and its
I took mine back to Bunnings and the guy there said they had a number with this problem and have found that priming the bulb 20 times not 10 as per the manual, is the fix.
It certainly fixed mine
Testimonial: "Thanks, will try it!!!"
SOURCE: stihl whipper snipper wont start..
I have a Sthil and the wiper snipper it starts but when I increase the power it seen to either stall or flood plesae help
SOURCE: what is the correct fuel
I believe Homelite calls for 40:1 (2.6oz. oil to 1gal gas) mixture, but if you are using a good current brand name two cycle oil, 50:1 (3.2 oz. oil to 1 gal gas) would be safe also.
