You can click this link:https://trueimagetech.com/blogs/all/brother-mfc-l2710dw-review
This is a website called true image that provides quality toner cartridges.
The toner cartridge that can be used for the mfc-l2710 brother printer is brother tn 760,you can purchase this toner on the website: https://trueimagetech.com/products/brother-compatible-tn760-black-toner-cartridge
SOURCE: New Ink Cartridge
Is the toner cartridge an original Brother or is it remanufactured? The toner cartridge for this model is the TN-350, which has a "flag gear" on the left (gear) side. It is a little plastic piece that sticks out on the new cartridges and, after putting the cartridge in for the first time, it rotates out of the way. This is how the printer knows that the cartridge is new. Some remanufacturers either don't put the flag gear in or they forget to turn it back to the original position when they build the cartridge. So that would be the first thing I would look at.
SOURCE: error 46 in brother mfc-440cn
Machine Error 46 ("Unable to Clean") indicates that the wasteink is full. Basicly it gives you two options - have it replaced (a semi-complicated performance which requires buying a spare part and change it yourself) or have it sent to service. If you do not have any warranty on the machine, the more suitable would probably be to just replace the machine instead, since it's relatively cheap compared to both service costs and having the wasteink replaced, but you instead get a full new warranty on your new machine.
Unfortunately, there's nothing you yourself can do to remove this error, without actually changing an item inside the machine.
SOURCE: BROTHER MFC 7820N MACHINE PUT IN NEW DRUM, CHANGE
To manually reset the counters, do the following:
(If nothing happens when pressing option, try using the back/clear button instead.)
SOURCE: Brother MFC-3360C cyan ink cartridge replace ment
On the front of the cartridge there is a sight tube for the ink, the fax shines a light through this tube to detect the ink.
I wraped a piece of paper around the tube to block the light beam on all the cartridges.
I dont need a processer to tell me if the machine is out of ink, I can work thay out when it stops printing!!
Now tell me you are out of ink you peice of electronic ****.
SOURCE: how to get ride of Toner life end message
You could try resetting the toner cartridge settings. OPen the machines front door where you would replace the cartridges. On the top panel you will see a "clear/back" button. Press it and on the display you will see a reset menu come up. Arrow to each one and hit the OK button. Press "1" to reset. Once you have gone through all close the front door of the machine and press stop to bring the display back to normal.
Hope this helps.
