Question about Boating
Transom mounted side imaging transducer is dripping a black tar like material or melted black plastic. I noticed this on my garage floor. Any idea what or why?
  • Boating Master
  • 1,586 Answers
That's the epoxy resin to encompass the piezoes inside the transducer housing ... Not a good thing to be leaking out .
Posted on Jun 30, 2019
6ya staff
SOURCE:
jerryg50
Jerry Greenberg
  • 1691 Answers
SOURCE: TRANSDUCERS
You have to order this from the manufacture.
Jerry G.
Posted on Jul 26, 2008
Anonymous
SOURCE: navman 4500 fish finder w/transom mount transducer
I finally got an email reply from Navman. If the unit is less than two years old (mine is not) they will repair it. If it is over two years old, or if you can't prove that it is less than two years old, you can ship it to them and they will repair it for the low, low price of 355 US dollars.
Pretty nice of them since it appears these units are highly problematic isn't it? I am wondering if they guarantee their fix, or just have you on the hook for another 355 dollars later.
Good Luck Everyone,
Walt
Posted on Apr 30, 2009
Anonymous
  • 10 Answers
SOURCE: bow mount 80lb to transom mount
Parts can be purchased from this dealer...There are schematics on the site for review....
http://www.northlandmarine.com/MinnKotaQuickRef.htm
Posted on May 08, 2009
TechnoMarine
John Barry
  • 132 Answers
SOURCE: Furuno sounder trandecer problems
the leading edge of the ducer should be higher than the aft portion. The leading edge must not be below the bottom of the transom. To determine if it is turbulence or radiated interference, put the boat in neutral and run motor up in RPM, if it fails then, with boat stationary, then proximity to motor is a problem and you should buy and in-hull ducer. glueing the transom ducer may or may not work well.
Posted on Jan 16, 2010
Best transducer location on transom for skeeter sl 210 I have hook and elite 7. Can they be mounted on the same side?
yes they can be mounted on the same side which makes cable routing easier. There is lots of information in the link.
transducer location on transom for skeeter sl 210 Google Search
Jul 30, 2018 | Boating
Can a inside the hull transducer be used as a transom transducer.
You could use it but you may not get accurate readings, best to get a transom transducer of find a way of mounting the one you have inside the hull?
Nov 06, 2017 | Boating
Sonar not Working
Transducer not parallel to bottom - kicked up. Manually set depth to see if the auto depth is the problem.
Aug 12, 2017 | Lowrance Elite-4x DSI Sonar with...
Lowrance X-136DF Fishfinder Not working
Hello Keneth,
Is The transducer In Side the Hull Or Mounted On The Transom?
If Inside Remove It And Re Fit It Using Epoxy Glue Ensuring No Air Pocket Between transducer And Hull.
If transom Mounted Replace Transducer.
Hope this Helps
Gordy
Nov 30, 2017 | Lowrance X136df Fishfinder With Dual...
I have a knocking (5 quick, loud knocks) sound intermittently on my refrigerator. I think it is when the compressor starts up (not 100% sure). I opened the back panel and everything looked normal except...
Chances are that black tar like substance you are seeing if from the capacitor. This is were I would start, as a capacitor is not all that expensive. Make sure it is the same rating as the current capacitor, and be aware that capacitors store electricity. When you disconnect the leads don't cross the terminals with your fingers, or you will get a shock. Hope this helps
May 05, 2010 | Refrigerators
My problem is I bought a 600l furuno and it came w/a thru-hull transducer and I wanted a transom mounted trans.I all ready bought a tr/mount and I need to sell the thru/hull.It's the 2" w/speed and temp...
i will exchange this for you, free shipping no charge, just ship it to me to inspect and i will send you the transom ducer no charge, if you have a bronze thru hull with speed and temp to trade for a plastic transom mount with speed and temp, let me know
Jul 29, 2009 | Furuno 520 5psd Plastic Thru Hull...
Aug 27, 2008 | Furuno GP7000F/NT GPS Receiver
Boating Logo
54 people viewed this question
Top Boating Experts
ray gallant
ray gallant
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Boating Expert? Answer questions, earn points and help others
