SOURCE: Hilti DD130 Core Drill gearbox Lubrication
Hi
220ml of synthetic 68 gear oil.
Hope this helps
Testimonial: "Appreciate the advice Wysepaul Can I ask from where this information is sourced? It makes sense that a synthetic oil is used. Any particular brand? Ta"
SOURCE: Cordless Hammer Drill Sfh 151 A 2.0Ah: Hi, How do you change the chuck on the Hilti SF 15...
Hi. open the chuck to the max. inside the chuck you will see a screw. remove it. put the drill in reverse. hold the chuck. a vice may be needed. pull the trigger. this may work, however in my experience, they are very tricky to get off. I have never had a faulty chuck but have had many faulty gearboxes. i have had to buy ney chuck to fit with the new gearboxes because i couldn't get the good chuck of the damaged gear box. good luck.
