SOURCE: LG AC compressor problem
Compressor may be locking up. Run capacitor may be weak or loose wire. Sounds like major voltage drop off as unit head pressure increases.
SOURCE: I have HAIER HPAC 99ER Portable air conditioner
Make sure your filter & the coils (area under the filter) are clean or that the evaporated water is not overfilled by draining it manually by pulling the plug on the lower rear of the unit (into a bucket of course.) I'm hoping you had gotten an answer sooner...
SOURCE: Haier Top Load Washer doesn't spin
Hi
There can be two possibilities,one if it has a belt, it is either stretched or slipping or if it doesnt have a belt then there is a clutch like device between the motor and the basket, which is either broke or cracked.
Or follow this easy steps...
Unplug the washer and turn off the water faucets.
Disconnect the water hoses and the drain hose and pull the washer away from the wall, leaving yourself enough room to work behind the appliance.
Lay an old towel down to kneel on and soak up any water that leaks from the hoses.
Remove the rear access panel.
Locate the motor. The rubber drive belt goes around a pulley wheel attached to the motor.
Press on the belt. If it gives more than ¾ inch or so, it needs to be tightened.
Loosen the mounting nut for the motor and push the entire motor to increase the tension on the belt.
Hold the motor in place and tighten the mounting nut.
Make sure you don't tighten the belt too much or it will break. You should be able to press on it and feel it give just slightly.
Replace the drive belt if it shows signs of wear.
Thanks for contacting fixya.com
Testimonial: "Thanks! I guess you're right. The belt seems to be too loose and shows signs of wearing. Already ordered new one. Thanks again!"
SOURCE: kenmore portable dishwasher won't drain model # 665 17799990
Service person said is is not supposed to drain all the way. Something about it helps something not dry out.
