Bosch french door series
SOURCE: Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
SOURCE: refrigerator compartment not cooling
If you are sure the fan in the freezer is running and you don't feel any air flow out of the top middle vent inside the fridge section, then the damper motor must be bad. The damper motor is behind that vent cover inside the fridge section.
SOURCE: Kenmore refrigerator
hi fperry74,
please look at the back bottom part of the refigerator , if you could see a small condenser fan there. it might not be running or running very slow. correct that problem then.
that is why your panel is very hot because a condenser line passes thru that panel and if the fan is not running, then the temperature gets very hot.
the efficiency of the fridge is also affected.
i hope i was able to solve your problem.
pls rate me.
tnx
drcool
SOURCE: Fridge freezer over heating and is not cooling fridge section
It is normal for the middle strip to be hot. Did you check the temp setting in the fridge section?
Also - you might check for blockage in the bottom. Excessive dirt/dog hair can block the air flow.
Good luck
SOURCE: lights on water dispenser stuck on & fridge is starting freeze
you have to give me model# so i can help you
