Kenmore KSM100 Stand Mixer Logo
Posted on Aug 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Will not spin dry - Kenmore KSM100 Stand Mixer
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 08, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
214
Points
Don't do you washing in your mixer. It makes your bread taste like dirty socks.
Anonymous
Level 2:
Scholar:
  • Expert 51 Answers
  • Posted on Aug 16, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
51
Questions
0
Helped
28811
Points
137
If your washer won't spin, check these:
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Thanks for contacting Fixya.com
I have a Hobart A200. My first gear it's spinning but I can actually hold it with my hands and will not spin, actually when I whip 4LB of bread dough it just wont spin,the hook gets jam
You have lost 1st gear. The gearbox will require dismantling and replacement of the 1st gear part (diving key) if they are still avaliable. I wouldrecommend contacting yout local hobart call center and speaking to their technical team about the age and probability of parts
Sunbeam heritage series 2346
Some lubrication might be in order. Grease will dry out and cake so it won't lubricate what it's meant to.
My bowl spins so fast that the ingredients flu out of the bowl
The bowl is not supposed to spin, it locks into the base of the pedestal. Engage the lugs and turn it one way to lock it up.
Kitchen aid mixer on but spining.
not sure that I understand. the mixer is on and spinning or it is on and not spinning. if it is not spinning it is a gear problem and takes about 2 hours to do and cost about 25 dollars. send us some more info and we can help.
1helpful
Why does my sunbean mixmaster bowl don't spin?
the spinning plate under the bowl does not have any power to spin the bowl; it only aks as a "lazy susan" carousel that allows the bowl to turn from the movement of the material being wipped in the bowl.
the beaters are purposely off-center of the bowl in ordwer to create a dragging motion of the material in the bowl, thus pulling (that is, spinning) the bowl slowly. If the beaters are not off to the side of the bowl, you will not get the pulling/spinning motion. Also, if the plate under the bowl does not move very easily, then the bowl will not spin. You may have to remove the spin plate and clean the center pivot for the plate to move freely. Good Luck, Macgivor.
I'm having oil leak out of the top of the unit? It's still working all right though, what could cause that? I don't want oil going into the mixing bowl.
It can be that the lubrication oil that was meant for the gear drives loosened off and flowed out. You can use a good wipe of the excess that have flown out, wash off with light oil and clean dry on the drive.
Occasionally you can check this to repeat the oiling and dry wiping so as to keep the top mechanism lubricated without total drying.
Bread hook use
Use it to the side. This will pull the dry ingredients off the bowl. If the dough is coming out lumpy, make sure you follow the recipe exactly. Putting dry into wet will give different results than putting wet into dry. If this doesn't end the lumps, try a different type of flour.
1helpful
Dry grinder
yes - dry well after wards
Top Kenmore Food Mixers Experts
NOEL
NOEL
john h
ADMIN Andrew
ADMIN Andrew
Are you a Kenmore Food Mixer Expert? Answer questions, earn points and help others
