Cut 3 pieces of wood a bit thicker than the new pads.
Jam then in the brake to relieve the pressure on the pads.
Undo 1 or 2 screws holding pad and pull out.
Reassemble reverse order
the motor spins with out the belt , makes me tend to discount the capacitor
I would be looking for a tub brake that is not being opened to allow the tub to agitate
there are solenoid activated brake under the machine the applies a brake when you lift the lid during wash, when the program is finished
have a technician check it out
The machine is probably not leveled properly. To level the machine, partly fill it with water. Make sure that the drum is standing in the middle of the machine and then adjust the machine until the water is at the same level all around at the nearest set of holes to the water. Check that the drum is still in the center of the outer drum. Make sure that the adjusting feet are all firmly on the floor and that you cannot rock the machine at all by hand. A top loader must be 100% level or it will shake.
You should be able to get a replacement agitator from partselect.com or repairclinic.com. look on line for an agitator however How old is the washer, would you give me the serial number.
