SOURCE: top half of screen doesn't show video, just menu
replace the main pcb also called the digital pcb.you also could have a defective address or
buffer pcb that feeds the top of the screen if the top is black.if screen is not black.replace the main digital pcb.where all video is done in
the tv.
SOURCE: Compaq Presario CQ40 Laptop screen flicker in
If a screen flickers it could be an inverter or a backlight problem. Not sure if it's cost effective to replace, though, in a laptop.
If it were a desktop, the video card could be added or replaced depending on whether the video function was on the motherboard or not.
Walmart is selling new laptops for $288 I saw this season that outperform a lot of computers from just a few years ago.
SOURCE: My dvd & usb is not working. Everytime i put a
the parking brake wire must be connected to the parking brake system of you car. When the parking brake is engages, the LCD will be allowed to view your video. If not, the screen will produce an image saying, parking brake. this is a feature designed for the driver not to watch a video while driving. The video output on this unit will not be affected by this, el wire to connect is Pink - parking brake. this is wire connect with ground.
On Most TVs I have messed with, Hit the input or source button muliple times to cycle throught the different inputs. Also make sure there is an active device on the input for the TV to recognize it. Good luck
