SOURCE: GE Max dishwasher no lights on panel
I have the same problem and actually found a workaround by mistake you may try as a temporary solution (if that works for you):
- press and hold the lock button for a couple of seconds
(the delay timer would increase by 1 hour)
- press and hold the lock button again
- repeat until it reaches 9hrs
- repeat one more time: the control panel should be functionnal again.
Let me know if that worked for you!
SOURCE: Problem with GE Profile Dishwasher
My delay start switch does not work and the dishwasher beeps periodically throughout the day. Also, I have it set for a 109 minute cycle and after about 20 minutes it says that I only have 35 minutes left in the cycle! Any suggestions?
SOURCE: i replaced the control panel on ge double oven
If the door isnt locked but the control board is saying it is you need to replace the door lock switch. You can get
required parts from online sites like:
--- www.repairclinic.com or from searspartsdirect online site. ----------- This should help.
Thanks.Helpmech.
---------- The door lock switch is not getting detected by the control panel.Disassemble the top door lock assembly, clean it and reconnect and see if that helps, if not then door lock switch has to be replaced.
Hi Kelly Kooken, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? What is your question? And what is the model number of your dishwasher?
