SOURCE: My remote control will not work
this worked on my kenwood vr-209.
http://blog.moertel.com/articles/2007/05/25/repairing-my-kenwood-a-v-receivers-remote-control-sensor
SOURCE: fujitsu air con unit. Remote wont work. has new batteries
Check the micro processor control whether it is in manual mode or not. If not check the sensor whether it is functioning or not. If everything is fine then remote control has to be changed.
SOURCE: hi my alpine rue 4203 deck there no image when pla...
hey mate i have the same problem.... any solutions?
SOURCE: My remote control is not responding. I even put
If the old batteries were dead for a while before you replaced them (or you took too long to switch them), your remote has probably lost the codes for your devices. You will need to program the remote codes again before it works.
If not, your remote is probably faulty - possibly the infra-red (IR) transmitter. You can use a video camera to check transmitters. The flashes are invisible to the naked eye, but can be seen through the view finder on a video camera.
Please rate this solution if you find it helpful. Thanks!
SOURCE: Remote control device doesn't work. New
Read this procedure to possibly fix the remote:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
They also sell replacement remotes.
Zoom in on the picture of the original remote provided on the site (or look at your own) and get the actual remote model number.
or check eBay: search for "(model of the device or the remote) remote", check the 'include description' box. Usually cheaper than the vendors.
