Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Have broken the drive gear twice Chamberlain garage door opener
I replaced the drive gear last year and now it is broken again. I noticed the door was raising very hard a couple of months ago and that the rollers on the door were sticking so I greased them. Not sure if the door raising is what caused the drive gear to break or not. Any ideas of other things to check?
    President:
  • 3,197 Answers
There are two main reasons for the drive gear to strip the teeth. The first and most often cause is a heavy door. With a door opener we never lift the door manually so we don't know how heavy it is getting when it needs maintenance. The second cause is what may be your problem and that is lack of lubricant. In the gear kit there is a tube of grease that should be used on the gear. You just can't use too much. You may need new door springs.
Posted on Aug 16, 2009
My Chamberlain Liftmaster Formula 1 garage door opener just started going up 2 inches then stopping. If I hit either the inside wall mount or the remote in the car it just goes back down 2 inches and back...
You need to check the door springs to see if one is broken and also remove the cover from the motor unit and check the drive gear. The gear is white nylon and will be very obvious if it is bad. The part number is 41A2817 and is available at any good door service company. It will come with instructions.
Apr 03, 2011 | Sears Craftsman LiftMaster Chamberlain...
Garage door only raises about two inches then stops.
Check the door springs and also remove the cover from the motor unit and check the drive gear. The door spring could be broken or the drive gear may be stripped.
The sensors only work when the door is closing.
Jun 15, 2010 | Sears Craftsman LiftMaster Chamberlain...
Door opened when i came home but opened slowly then would not open again makes adelayed tumpping sound then doesn't do anything.
You need to check your door springs and the drive gear. You may have a broken spring or your drive gear may be stripped. Remove the cover from the motor unit and it will be obvious if the gear is bad.
Mar 13, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have replaced the worm gear assemble twice in my craftsman 1/2 hp garage door. what am i doing wrong. why does it keep turning to dust
Use that small tube of grease in the kit and smother the gear teeth with it. Use it all. Also disconnect the opener from the door and lift the door by hand. It could be the springs are either broken or so heavy the opener can't survive lifting it.
Feb 12, 2010 | Sears Craftsman LiftMaster Chamberlain...
GARAGE DOOR OPENS ABOUT 3 INCHES AND STOPS
Check the door springs. May have a broken one. Also remove the cover and look at the drive gear. It is white nylon and is just in front of the motor. It could be stripped.
Sep 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door barely opens/ opens with physical lifting assistance
It sounds like you have a broken door spring or the drive gear in the opener is stripped. You will have to take the cover off the opener and you will find the white nylon gear just in front of the motor.
Sep 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
My Chamberlain garage door opener only opens 8 inches.
Sounds like you have broken door springs or a bad drive gear. Take a good look at the springs and then remove the cover and look at the gear. It is white nylon and is just in front of the motor.
Sep 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
The nylon drive gear on Craftsman Garage Door keep stripping
The most common reason for this is a door that is too heavy. Release the door from the opener and lift it by hand. If it is heavy to you it is heavy for the opener. Be sure after replacing the gear to lubricate it heavily with the lubricant supplied with the gear. You can't apply too much.
Jul 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain 1/2 hp heavy duty garage door opener stops working until you tap hard on the back of the box to get it going again. Not even the tapping will get it started now.
I have three of these openers and all have failed after several years use from the plastic drive gear wearing out, so without seeing your unit, that's what I would guess. The gear is relatively easy to replace and I bought parts from a company called "gatehouse" (www.gatehousesupplies.com). I've only used them once, but I am pleased with the service. Good luck.
Jun 11, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
Stripped Gear on Liftmaster
how handy are you. can anyone do is a silly question. a blind person with no hands could not do. you need a socket set, hammer,screwdriver/allen wrench. kit costs $25-30 dollors. Gears will last as long as originals, not one year. It will take you 2-3 hours for a first timer. Takes me 30 minutes to rebuild unit once I take down and 20-30 minutes to reinstall, if you can change a washer or install a faucet, you can do it. what do you lose vs. what can you save.
Dec 20, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
334 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
