Sounds like a shot of WD40 on the catches and pivots might help. It is kerosene based so will clean and lubricate. I looked for videos that might mention this fault, but there aren't any.
ThermadorContact us for help with service & repair needs. ... The anti-tip bracket is not needed for 48" Harmony units. However, the anti-tip ... Oven light is not working properly. Replace ... Buy a replacement bulb. View the ... The rack positions that you would use when baking 3 racks in the convection mode would be racks 1,2 and 4.
Huge selection of Thermador Range/Stove/Oven parts in stock. Same day ... Stove top potentiometer Kit that contains 2 potentiometer's and 1 simmer controller.
Hi, Check fuses on the stove. Check the breaker panel for correct breaker and if breaker has tripped.
Then you will have to ask a technision to look at it further. Good luck
I'll start by saying, I just received an email saying you were asking me a direct question...I will tell you what I know based on my experience with Thermador (extensive) and the description of your post. This sounds like a possible hi-limit thermostat tripped scenario.
I don't know if you know where it is or how to check it, or if this is the case with both upper & lower ovens...but they are independent of each other on the SC302T, so if you can reply and elaborate I'll b glad to help in any manner I can. Thank you for choosing FixYa.
Hi, Try turning the power off and then back on after a few minutes... if that does not fix it often the best thing to do is to call the manufacturer cust. service number and let them talk you through it...
