SOURCE: wont start without starting fluid
Could it be a plug up injector , have sewiing needle , stick it in the sprayer part of the injector on the carberator part
SOURCE: Maytag washer wont start spin cycle...
INSPECT YOUR PUMP HUMMING NOISE USUALLY PUMP MOTOR ARE PRETTY RELAIBLE
SOURCE: My Kenmore Washing Machine wont drain or spin. Only a slight hum.
This problem is commonly attributed to a lid switch malfunction. If the model number you have this listed under is correct, the lid switch is mounted under the washer top casing, on the right hand side. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. The humming sound you hear when the lid is closed may just be the timer motor running. If your washer is not configured in this manner, please post back with your COMPLETE model number (located along the tub rim under the lid) so I can confirm how your washer IS configured. I hope this helps you.
If you determine that your lid switch is broken, please let me know and I will provide you with the steps necessary to repair it yourself (simple repair job). I can also give advice on where to purchase a replacement.
NOTE: Placing heavy objects on the washer lid can cause the lid to bow and also affect the way it contacts the lid switch.
SOURCE: I have an ITT marlow bath spa pump which runs fine
If this motor is not turning then you will likely need a new motor. it has brushes inside the motor like a cordless screwdriver.
There are no parts for it. you will need to find another one.
http://www.uspartscenter.com/index.asp?PageAction=PRODSEARCH&txtSearch=nr2ac&btnSearch=GO&Page=1
SOURCE: pump just hums but wont start
Sounds like its frozen and causing a very heavy load on your circuit. If the motor gets hot within seconds, its shot and needs replacing. Have you attempted to turn the motor over by hand ?
