Unless the unit was moved and RGB section misaligned, the other condition could be a defective controller circuit board.
If it is old, heat builds up over time and the components start to breakdown. Remove the back of the TV and see if there is a collection of dust and debris that could effect the operation of the TV.
Nope, But your convergenjce chip is about to die. i would turn it off and leave it off and call a tech to rectify it before it takes out the whole board or all 3 as some capacitors are also overheating. Parts $100+Labour of about 1.5 hrs at this stage! later it will be $600
have you gone into the menu and tried to adjust the convergence back if you have and it doesnt move you have a convergence ics that have failed and they will have to be replaced
if you have the tools a soldering station and some knowledge you could replace them your self or you may want to enlist the help of a local servicer in your area
Hi, did you try a color convergence? I used to work in Best Buy and one of the key things about rear projection TVs and the reason they push those service plans on you is that the tubes/colors need to be calibrated each year. You can do this yourself by checking out the following website:
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=3229 Hope this helps :)
TRake the fron grill off and the front board 6- screws on my 65inch there are three adjustment knobs one of them wil adjust the huge
one the whole screen,if not that,I have heard mold growing on and the inside of the blue bulb because it runs the coolest out of the three.
