Check when you turn the control knob inside the fridge side that there is some form of resistance or at least a sweeping sound. The knob will always stop at both extremes but very often the linkage can come loose leaving all the cool air above in the freezer. if you can unplug the fridge and listen very closely to see if the deflection door is indeed moving. If you can get the cover off, grab your surgeons cap, a flash light and a long pair of needlenose pliers you may be able to clip the link back in place. Good Luck,Dana
