SOURCE: kenmore washer
Yes I fixed my washer problem.
The washer was stopping before it would drain and spin. I would raise the lid and then close it back and it would start back up. So we figured the lid switch was broke.
Before you do anything you "unplug" the washer!
You have to pop the ends off the back panel with the buttons on it. Then you unscrew the 2 screws at the bottom of the panel and raise it up. Then you remove the brass clips that are holding the lid on. Then you move the whole washing machine cabinet out. My husband replaced the lid switch. Then we had to figure out how to get the cabinet back on right. That took some time but we did it. Then you repeat everything you did to take it off to put it back together.
The washer is working fine now.
SOURCE: Hi I have a whirpool washer that is 7 years old, I
The most common cause of the symptoms you describe is a broken motor coupling. Whirlpool manufactured top loaders use a motor coupling in place of a drive belt and are known as "direct-drive" systems. No agitation, or spinning, associated with a grinding noise are the usual symptoms. The washer should still have the ability to drain, however.
The following link explains how to access the coupler and replace it, if necessary:
http://www.fixya.com/support/r3574231-replacing_a_motor_coupling
The part number is included with the instructions I provided. Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need. If you do not wish to order parts on line, use the part numbers I provided and go to your nearest appliance parts retailer. The coupler is usually sold as part of their in-store inventory. The average cost of a motor coupling is only about $15.
If you have any questions, or if the symptoms I describe do not match the problem you are having, please post back and let me know. I hope this helps you.
SOURCE: I was given a whirlpool
Usually the model number is on the lip of the inner rim of the washer when you open the lid...near where the water comes into the basin. But even if you can't find the part number for the switch or the washer, you can just defeat the switch by taking the two colored wires from the switch and twisting them together...no switch needed then!
