My Admiral Washing Machine only trickles water on the cold cycle. The hot water runs fine,after a few seconds it goes to cold and I only will get a trickel again it nevers turns back to hot for a full flow.If I turn the knob off than back on it will give me a full flow for about a 30 seconds and than slow trickle, could this be a switch sensor or a control problem? If I fill the machine up by a buckets of water everything else works. Thank you
I think the water inlet valve is nearly stopped up with sediment in the screen filter where the supply hose screws to the valve.Cut the water off at the hose and disconnect and look for the screen. The hot water usually doensn't do this because the water has time to settle everything out while it's in the hot water heater.
