If you have forgotten your Password. Then you don't worry, you just click here at this particular link Belkin Support Belkin Router Support Number 1 800 335 8177 Belkin Help At this link you will get to know how to Reset your Password.
There are two possible solutions, depending on which password you can't remember. If you remember the password to log into the router, you can go to the wireless security page and see the wireless password (you may have to uncheck the "obscure password" box to see it). If the password you can't remember is the one needed to log into the router, I believe your only recourse is to hold the reset button for at least 10 seconds to restore the factory defaults. NOTE: you will then have to re-configure the router as if you had just taken it out of the box.
SOURCE: router password
The default password, as aderenzo says, is "admin". If that does not work there is a restet button on the router somewhere. Press it and hold it for 5 seconds. This will restore the router to its factory default and reset the password to "admin". The username field should be left blank.
SOURCE: zyxel wireless router password
you could go to the control panel then network connections then setup wireless network and click on add a network and save the files on a usb then insert the usb to the laptop there you have it you can use internet on your laptop after you install
SOURCE: I can't remember the password for my router. I
hi
In your case you have to go to your service provider for more free technical you can visit---http://robs-tech.blogspot.com/2009/06/free-solution-regarding-computer.html
SOURCE: how to change password for Trendnet TEW 432BRD wireless router
type in your address bar
192.168.0.1
username is admin
password is password
those are default
