SOURCE: my lenovo v460 (i5) seems to have a push-push sim
Most Lenovo Computers provide Sim Slots for PC, but they are not equipped with a 3G Modem. You need to get that separately.
The description on Lenovo is 3G ready, meaning you could use it if you have additional parts installed; in this case, a Mini PCI 3g Modem
Hope this helps
SOURCE: hi. i have lenovo b40 laptop
Sim card slot is very much like a sim card slot of your cellphone, you can use it to call, to browse the internet and also to receive a call.
SOURCE: how can i use sim card slot that is consider under the battery in my laptop?
insert your sd sim card
click start click on computer to open you should see your drives C: and your other drives cd dvd and your sd card usb drive E: or F: from there you select the files right click on the file/s right click copy navigate back to the drive right click select paste or hold the mouse cursor the file/s drag them to usb drive then drop them example on how to safe data/files to a usb drive
click start all programs accessories open windows explorer navigate to your data
right click on the data select copy navigate back to the usb drive right click select paste or select the data hold the mouse cursor then drag the data to your usb drive then drop it in
or if you are downloading data from the internet
once it starts downloading windows will ask whether you want to run or save it
a browse option will open you can save it into a folder in my documents or another device or a usb device
if you need more help with this post a reply
hope this helps you
SOURCE: i have lenovo G560 laptop.in this laptop i saw sim card slot under the battery so how can i use it
The SIM card is for mobile broadband (wireless internet anywhere you have cellphone service).
Before using Mobile Broadband, you first need to choose a mobile networkoperator (such as Sprint, Verizon, AT&T, T-mobile, etc.) and make sure you are in the coverage area of the network.
After that, you also need:• To activate the Mobile Broadband service through your local mobile network operator. Youwill get a Subscriber Identity Module (SIM) card after activation.
Best regards,Abdielcomputer repair plantation
Ok, I stand corrected. I never knew this technology existed. I looked at your manual and it indeed shows a sim card slot. The manual also gives instructions on how to insert it and what you have to do to make it work.
Below is a link to your manual.
http://download.lenovo.com/UserFiles/UserGuide/en/User%27s%20guides%20and%20manuals/B460/Lenovo%20B460%20User%20Guide%20V1.0.pdf
