Mary Heady Posted on Jun 24, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Onkyo TX SR 313 receiver display is not working. Machine sounds like it turns on, but the display is totally void of life. How do I fix the display?
Ambrosia Heart
Level 2:
Loyalty:
Visited the website for 30 consecutive days.
  • Expert 133 Answers
  • Posted on Jun 24, 2019
Ambrosia Heart
Expert
Level 2:
Loyalty:
Answers
133
Questions
0
Helped
67776
Points
383
You need to check several voltages
(1)-VP
(2)FLAC1 and FLAC2
(3)drive signals to FL needs a digital storage oscilloscope to observe waveform. Or replace chip directly.
This is a full picture.
Onkyo TX SR 313 receiver display is not working. M - 908dbf94-3096-4575-8951-a0946c36b72f.jpg
5 Related Answers
A
Anonymous
  • Posted on Jul 12, 2008
SOURCE: No video through HDMI section of Onkyo TX SR-805 receiver
My has problems with losing video on HDMI, component, or svideo, this is a piece of you know what!
Rami Obeid
  • 16 Answers
  • Posted on Nov 15, 2008
SOURCE: Onkyo TX-SR 606 KEEPS CLICKING INSTEAD OF TURNING ON WHEN POWERED
Here are your options:
1. An electrical problem, where your receiver has a grounding problem.
2. Your speaker wire connections are actually touching each other and that's why your receiver is not turning on.
Anonymous
  • 25 Answers
  • Posted on Dec 29, 2008
SOURCE: My Onkyo Receiver TX 601 is turning itself off
Adjust bass control to half position then feed loud signal,if it shut off adjust the bass contol to zero position,if it shut off again the defect is in the over load protection circuit it is already sensetive to loud signal.you may call the nearest audio amplifier technician on you.
Hope it may help you,
Anonymous
  • Posted on Mar 12, 2009
SOURCE: Onkyo AV Receiver TX-SR 805 no display on the receiver
Finally one of us found the solution - thanks to cambrian
Please follow the link
http://www.avsforum.com/avs-vb/showthread.php?t=857502&page=579
BTW: My knowledge of electronics is very limited, but nevertheless I could fix the problem. I hope you can do it too.
Anonymous
  • 8546 Answers
  • Posted on Apr 25, 2009
SOURCE: how to hook up bose series 2 eq to onkyo tx sr 875 receiver.?
I wrote most of this for a different receiver, but if you account for minor differences to your receiver this will work just fine.
There's good news and bad news. The bad news you need a separate amp because a multichannel receiver with Bose 901's attached as recommended for a standard stereo receiver will only sound right in STEREO on stereo analog material. The other speakers around the room are not designed to receive its Active Equalization and if you engage your Tape Monitor you will NOT BE ABLE TO HEAR DIGITAL sources at all. Tape Monitor is for analog stereo material only and on modern AV receivers it disables any digital inputs so you really can't use the Tape Monitor circuit or attached devices for modern digital sources. However, you can still employ the various DSP options to spread 2-channel analog source material around the room. I do.
The good news. I have a setup similar to what you want to do and it works great! I see on the SR875 there are Pre Audio OUTS. This is easy.
A separate stereo amp for the 901's was my solution. I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver Front L&R Outputs and the 901's amp channels. My receiver controls everything and just drives the Center and Surround speakers.
You could get by with just a stereo amp for the 901's. A Carver M-200 is a good efficient amplifier that would have you cooking just fine (2x100W). Run it with the Active EQ between the receiver Front L&R Pre-Outputs ** and the 901's amp channels.
** Front Pre Out >>> Bose EQ Amplifer IN, then
Bose EQ Amplier OUT >>> new amplifier IN.
Attach the 901's to the new amp, set its volume to Max and run through your receiver's speaker level setup.
How to fix Onkyo TX SR 303 when it says phones engaged but no phones are not plugged in
Hello, I suggest a reset of the receiver. Please see the procedure below. Thank you, Onkyo USA.
To reset the AV receiver to its factory defaults, turn it on and, while holding down the [VIDEO 1/VCR] button, press the [STANDBY/ON] button. "Clear" will appear on the display and the AV receiver will enter Standby mode.
Onkio receiver TX-SR 505 DISPLAY tube has 3.8 acv ,is off
Your Onkyo has the 3.8 VAC which normaly is correct for normal operation of the display. Make sure you have a SM to help you troubleshoot the problem.
No volume coming through. I have a Panasonic tv
What sound from what source? Is the TV the source of the sound ? If so, why? The best TV-related sound would be had from the cable, dvd, bd or whatever else it is showing. Your TV could be the reason you cab't hear it.
What still works? FM? CD? Have you cracked the manual to see what it recommends? How about running through the basic speaker setup again to see how that works out.
While wathching TV, the typical volume level
Cleared all AV settings and reprogrammed.
The display on my Onkyo TX-SR 803 is blank does not light up. Everything is functioning properly. Volume light is lit. Any suggestions.
This is a common fault, I got in touch with Onkyo and they referred me to a company called GenServe based in Swindon.  My receiver was under warranty and I live near Swindon.  The company was very helpful and fixed the problem in a couple of hours!  It's worth calling them on 01793 886333. www.genserve.co.uk
1helpful
Dont understand
this is retarded comment .... 20 what is 20 ? this is not how we compare receivers.... you ****...
Onkyo tx sr 605
well most dvd aint 7.1 are using dolby digital cable in digital mode ect on sterio set output on ps3 audio setting to digital
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
John
John
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
