SOURCE: How do you delete pictures
You can open your player through My Computer and delete all the files in the Albums folder to get rid of the album art.
SOURCE: Sansa C240 syncing problems
The songs are in the wrong format - read my 2-part article on song formats under my profile for more detailed info
short answer: convert the songs to Mp3 format, and you will have no problems
SOURCE: Taking songs of my c240 sansa
To delete songs from your device follow the steps below
You have to make sure that the device is on MSC mode...then make sure your device is plug in to the computer..Then go to programs - accesories - windows explorer, find the SanDisk in my computer, go to media, music and delete them from there.
Either under sync panel in your windows media player it will show your music when it's connected. just click the plus signs for what song you need to get rid of, right click and click delete.
To format it..on your device..go under..menu, setting and there should be a format option option there..let me know if that doenst work for you...
Hope this helps
P.S.Please rate accordingly...
Thank You
Computerrep
SOURCE: will itunes transfer songs to my sansa c240?
No you wont be able to use itunes to transfer songs to your sansa but you can transfer songs that you purchased from itunes using your windows media player to your device...All you have to do is to add all the songs your purchased from itunes to your windows media player library and then you will be able to transfer them to your device..
I hope that helps
Thank you
Computerrep
SOURCE: am unable delete song...they do not show up on my computer either
I have a dffierent mp3 player Colby with a usb and I had the same problem. Try deleting the songs from the device itself. If you go into folder view if you havet hat option and choose the song it says to play or delet, at least that is what mine says. It may take awhile to do it one song at a time, but you should have the option of deleting the songs from the actual mp3 player.
I also had minenot show up, mine was do to deleting some of the software off of the player to make more room for songs. I never used podcasts and other files that came on it, so after I deleted them my songs stopped showing up. I just copy the songs to my mp3 player now, and delete them one by one. Hope this helps you.
songs don"t show up?
