Question about Krups KM7000
Km7000 will not brew
Additionally the warming plate will not heat up
    Scholar:
  • 22 Answers
Mine had the same problem ... all the lights are on, no heat on the plate and no dripping water.
After a weekend on the workbench, I've mastered this machine. The KM7000 has 2 x MicroTemp G4 thermal cutoff (TCO) fuses which interrupt the Live line, for overheat protection. Mine didn't overheat per se, but the TCO blew anyway. Not reset-able ... need to be replaced with a soldering iron. I'll be happy to advise you to fix this, or fix it for you. Write me at KM7000@flightsystems.biz
Posted on Jan 31, 2010
    New Friend:
  • 17 Answers
Your heating plate/water heater has failed. Krups replace my whole unit.
Posted on Dec 22, 2009
6ya staff
SOURCE:
Krups KM7000 won't make a full pot.
I have one. there is a setting on how many cup you want 4,6,8,10, or 12 cups
Oct 18, 2012 | Krups KM7000 10 cup Grind and Brew coffee...
Excessive steam when brewing krupps km7000
NOT THE SAME problem as listed!!
I'm now experiencing what the original poster is experiencing, I've fixed the thermal fuse problem twice so far over the last two years. The thermal fuse allow the water flowing through the tube under the plate to heat witch forces it up to the brewing lid, if the fuses blow = no heat= no steam.. we are experiencing EXCESSIVE steam and verrrry slow brewing. Mine takes over an hour to brew half a pot and I have to fill the reservoir twice to get 2\3 of a pot.
It's all going to steam,, suggesting, to me, the temp is getting WAY TO HIGH.
Am I right? does anyone have any more info or clarrification.. and what part might fix this.
how is the temp getting too high.. is there a temperature "SWITCH" somewhere?
Feb 21, 2012 | Krups KM7000
Krups KM7000 grinds but won't brew, warming plate no heat. Is this repairable, (perhaps a fuse?) or is it junk. Bought the machine in March 2008
Mine had the same problem ... all the lights are on, but no heating on the plate, and no dripping of water.
After a weekend on the workbench, I've mastered this machine. The KM7000 has 2 x MicroTemp G4 thermal cutoff (TCO) fuses which interrupt the Live line, for overheat protection. Mine didn't overheat per se, but the TCO blew anyway. Not reset-able ... need to be replaced with a soldering iron. I'll be happy to advise you to fix this, or fix it for you. Write me at KM7000@flightsystems.biz.
Oct 30, 2009 | Krups KM7000
My Krups Grinder Brewer has stopped pulling water though the system. It just stays in the resevoir. Grinder part seems to be working fine.
Oct 09, 2009 | Krups KM7000
Krups KM7000 won't brew
Your heating plate is your hot water heater, and most likely failed. Krups replaced my whole unit.
Oct 07, 2009 | Krups Coffee Makers & Espresso Machines
KRUPS KM7000 POWER IS ON AND IT GRINDS BUT DOES NOT BREW THE WATER TO MAKE COFFEE.
Check to see if your heating plate warms up, if it doesn't then your water heater/heating plate has failed.
Oct 02, 2009 | Krups KM7000
Krups KM7000
Check to see if your heating plate heats up, if it doesn't then your water heater/heating plate has failed.
Sep 08, 2009 | Krups KM7000
Got a Krups KM7000. Coffee grinds but no water to brew coffee.Just clicks. then nothing. Tried to reset by unplugging but no help. Grinds everytime even when it's not supposed to. Water will not dispense.
This seems to be a common problem with this rig. So far, I've helped 13 people on this site with exactly the same problem ... all the lights are on, but no heat on the plate and no dripping water.
Aug 24, 2009 | Krups Coffee Makers & Espresso Machines
Water will not drop to make coffee....
I your plate is not heating, no water will flow. This seems to be a common problem with this rig. So far, I've helped 13 people on this site with exactly the same problem ... all the lights are on, but no heating on the plate and no dripping water.
Jul 31, 2009 | Krups KM7000
Grinds but won't brew
If your plate is not heating, no water will flow. This seems to be a common problem with this rig. So far, I've helped 13 people on this site with exactly the same problem ... all the lights are on, but no heat on the plate and no dripping water.
Jun 19, 2009 | Krups KM7000
Krups KM7000 Logo
327 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Pierre Laplante
Ray Murphy
Marvin
Marvin
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
