Samsung DVD-R155 Logo
Posted on Aug 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Samsung DVD-R155. When I insert a DVD, the screen reads "load", but eventually it screen will say it can't read the DVD, and then ejects the DVD. It doesn' t matter if it is a new or used DVD. I have the same problem, insert new dvd-r disc and it says loading then spits the disc back out with a "disc cannot be read" message
Anonymous
Level 3:
Brigadier General:
  • Master 4,090 Answers
  • Posted on Aug 15, 2009
Anonymous
Master
Level 3:
Brigadier General:
Answers
4090
Questions
0
Helped
1184295
Points
12747
Try using a DVD scanner eye cleaner. It is aDVD with a brush grafted to it. I suspect the scanner eye is dirty so it cannot read the boot starp properly and so ejects
2 Related Answers
Anonymous
  • 98 Answers
  • Posted on Nov 25, 2008
SOURCE: player won't read a DVD
Sounds like a bad pick up assy (Laser)
Anonymous
  • Posted on Oct 04, 2008
Some DVD players requires installation of software to load some DVD's. Ask your dealer to provide you with a Software CD. Just insert this software CD and then try to run DVD it will work...
1helpful
Dvd door will not open on my Samsung dvd model R155
The gears are jammed, or the timing gear is out sync, or a bad loading belt, plus in rare cases, the gears crack or break.
1helpful
My dvd recoreder keeps saying cannot read disk. keeps ejecting disk when ever i insert a disk
get a laser lens cleaning disk .($2 to $10) . it looks like a standard CD but has fine little burshes that remove dust from the laser ...that may not work if anyone smokes around the machne .. in that case the cover has to be removed and the laser manually cleaned (with eye glass cleaning fluid on a soft paper towell) ..if that doesnt work then the laser may be just worn out ... replacement is usually more than the cost of a new unit ... make sure your disks are clean .. you can wash the shiney side with mild soap and water ... rince and pat dry .. dont use hot water ...
4helpful
2answers
Code for unlocking dvd regions samsung r155
hi,
1.Turn on R155 without disc inserted
2. Press and hold Play and Stop for 5 seconds then release
3. Press menu
4. enter code for current region as above i.e if you have a region 4 type: 7, 6, 8, 8, 4
5. The region is displayed in the top right.
6. You have about 5 seconds to enter the new region (1,2,3,4,5,6 or 9 for multiregional)
Region codes for Samsung:
RC 1: 2, 9, 3, 3, 4
RC 2: 3, 8, 7, 6, 7 (or 5, 7, 5, 3, 8)
RC 3: 5, 6, 7, 3, 2
RC 4: 7, 6, 8, 8, 4
RC 5: 5, 3, 8, 1, 4
RC 6: 2, 4, 4, 6, 2
Thank u
LG DVD recorder not playing DVD
When a unit does that it can be a fingerprints on a disc not letting it read the disc and or also that it is not finalized. Can also be a disc format that does not work on unit. Some units only work with either -R or +R and not both. Hope this helps
2helpful
2answers
Player won't read a DVD
Samsung sh-s182 not read cd's and dvd's
So you mean each time you insert the disc it ejects automatically?or you have a problem reading with the disc?
2answers
Does the DVD-R155 create PC compatible DVDs?
just try to load the dvd disc.and see if it is reading..
The dvd player will not eject the dvd
We once had 2 DVDs in the tray (thanks, kids). The tray would not open and had similar symptoms.
We eventually pulled/pried-open the tray (while it was attempting to open by itself, aka you could hear the try motor was activating.)
I'm sure a tech would cringe at this, but it did eventually pop open (with our aggressive help) - and all is well.
Good luck.
3helpful
2answers
Dvd hr720
Had a similar problem after loading a suspect dvd (one I had burned myself) Could not do anything - stuck at loading. Don't remember if the fan was running. From what I have read these units are touchy to bad disks (DVD or HDD) If yours has a DVD inserted try this :
  1. Unplug and wait 10 seconds
  2. plug it back in and wait 1 minute. DO NOT PRESS ANY BUTTONS!
  3. With the machine still in the standby state, press eject on the REMOTE. It should eject without trying to read the disk.
Good luck. It worked for me.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
