Why won the machine pick up the bobbin thread BrotherOne Point Advice Place a spool of thread on a spool pin.
One Point Advice Upper threading
- Remove the bobbin and make sure the bobbin is threaded properly in the shuttle race.
Remove any loose threads or lint in the shuttle race.One Point Advice Installing a bobbin into a bobbin caseor this link might help you out some more.
- You could be holding the needle thread too tight.
Hold the thread lightly to keep the end from going down into the shuttle.- The needle could be thread incorrectly.
Thread the needle eye from the front to the back.- The needle could be bent or improperly inserted.
Install a new needle with the flat side of the needle facing the back.
Generally, this is because the needle
is inserted wrong or because it's bent. In the first case, the top
of the needle (called the shank) has a flat side-this has to be
inserted so it faces the back or away from you.
In the second
case, when a bent needle stops the top thread from picking up the
bobbin thread. Even if you think your needle is fine, change it to
see if this solves the problem.
In the second
If this doesn't work, leave me a comment. I check back daily, so I'll see the comment and will see what more I can do to help you, most likely within 24 hours.
