The easy solution is to buy a new universal remote cost about 8 to 10 dollars but if you dont want to spend money just point the remote you have to the tv. and start clicking
till the tv. is off thas the solution
If you have a new remote control for your television and you don't have the manual, don't worry. You can still try to link or program the remote to your television by following these general steps:
Identify the brand and model of your television: Look for the brand name and model number of your television. This information is usually located on the back or side of the TV itself. Knowing the brand and model will help you find the correct remote control codes for programming.
Search for remote control codes: Most remote controls come with a set of codes for various television brands. Without the manual, you can try searching for the remote control codes online. Many websites and databases provide lists of codes for different TV brands.
Entering the codes manually: Once you find the code for your TV brand, follow these steps to enter it into the remote control:a. Turn on your television. b. Press and hold the "Setup" or "Code Search" button on the remote until the indicator light turns on. c. Enter the code for your TV brand using the remote's number buttons. The indicator light should turn off if the code is entered correctly.
Test the remote: After entering the code, try using the remote to control your television. Test functions like power on/off, volume, and channel buttons to see if they work correctly. If they do, the remote control is successfully linked to your television.
If you don't have success with the first code you find, try other codes for your TV brand. Sometimes, multiple codes are available, and you may need to try several before finding the correct one.
If the above steps don't work, it's possible that your remote control uses a different method for programming. In that case, try searching for the specific programming instructions for your remote control model online. Manufacturers often have manuals and programming guides available on their websites.
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily. http://remotesearch.blogspot.com/ http://electronicshelponline.blogspot.com/ http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window " to get gathered related posts.
RCA universal remote control have no set-up code/s to Magnavox devices. Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily. http://remotesearch.blogspot.com/ http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/ http://electrohelponline.blogspot.com/ Programming Notes
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily. http://remotesearch.blogspot.com/ http://electronicshelponline.blogspot.com/ http://electrohelponline.blogspot.com/
Programming Notes
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts.
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts. http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order.Pull up older posts. Surf the site with patience. http://remotesearch.blogspot.com/ http://electrohelponline.blogspot.com/
Then here is a site that instructs you how to reprogram the remote with the code for your tv.. ( it also has a list of codes for different brands of TV's at the bottom)
codes for magnavox tvs: 0054, 0030, 0179, 1254, 1454
the programming procedure is as follows: 1) turn on tv 2) on the remote, press "tv" 3) press and hold set until the led blinks twice, release set 4) enter the 4 digit code, light should blink twice 5) aim remote at the tv and press power, the tv should turn off 6) if it doesnt, repeat steps 2-5 with the next code on the list
cannot get television remote to program
