Kohler BALLAD 25X22 Stainless Steel Kitchen Sink - 1-HOLE K-3258-1-NA Logo
Posted on Aug 14, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What size hole in new counter to fit 25x22 neptune by elkay sink. It uses clips from undercounter
Anonymous
Level 2:
  • Expert 88 Answers
  • Posted on Aug 23, 2009
Anonymous
Expert
Level 2:
Answers
88
Questions
0
Helped
39683
Points
205
Cut hole smaller the the sink sizeso sink rest edges on countertop
Elkay kitchen faucet model lk7124 replace stem
ELKAY ' Strainers, Fittings + Other Accessories for the Home
www.elkay.com/strainers-fittings-other
Results 1 - 15 of 91 - CERAMIC LONG STEM SQ MNTG COLD. 45921C. Brass. Price pending ... CERAMIC SHORT STEM SQ MNTG HOT. 45924C. Brass.
ELKAY ' Stainless Steel Kitchen Sinks, Faucets, Cabinets ...
www.elkay.com/
Elkay is an American-owned and operated innovative manufacturer of stainless steelkitchen sinks, faucets, foodservice products, cabinets, drinking fountains ...
[PDF]SPECIFICATIONS
aitcheson-dc.com/files/2012/07/EL.LK2432.pdf
LK2433 Dual handle, concealed mount mixing faucet. Metal ... (101.6mm). ModelLK2433 ... Hi-Arc® Dual Handle Kitchen Faucets. Models ... Elkay warrants to the original consumer purchaser that the Elkay faucet pur- ... replacement parts (or if no longer available a comparable product) if the faucet ... METAL STEM.
Amazon.com: Elkay - Faucet Parts / Rough Plumbing: Tools ...
www.amazon.com > ... > Faucet Parts
Amazon.com, Inc.Results 1 - 24 of 921 - Elkay GOBG1118SS Dayton Kitchen Sink. by Elkay. $44.50 ...Elkay A51947R Replacement Diacore Cartridge with Brown Stem. by Elkay.
Elkay A51947R Replacement Diacore Cartridge with Brown ...
www.amazon.com/Elkay...Replacement.../B0033UX8...
Amazon.com, Inc
Cutting a new counter top for a sink
If you are installing a basic stainless steel sink into a laminate over particle board counter top-
Find the center of the sink along the legnth of the counter and mark the counter. Measure the sink from the top. Lay out the edges on the counter. Place the sink upside down on the counter and align with your marks. Trace around the sink in pencil. Subtract the distance to the flange where the clips slide in. Draw a new line inside the first one. This is your cut line. Check that when you make the cut that you will not hit the face frame of the cabinet. Move the sink back if needed and make new marks. Some cabinets are a tight fit. Cut the hole for the sink with a jigsaw. Start with the back line first. You may find on a counter with a back splash the jigsaw will not fit. Drill an 1/8" hole to mark the underside and cut from the bottom of the counter. Use a 1" spade bit to drill starter holes at the corners keeping away from the line you traced when the sink was upside down. Stay away from that line or you will have a hole the sink won't cover. Cut the front line. Drill a hole in the center of the counter you can put your finger in to catch the piece when it falls. Now cut the side lines while supporting the counter that is being removed. Discard the slug you removed.
Test fit the sink and remove any extra until the sink just drops in. Remove the sink and set it aside. You need at least 2 sink clips on each side of the sink but use 3 if you can get to them. Determine the location you want the clips at. Use the 3/4" spade bit to drill uot a pocket for the clips to go into. They will normally hit the bottom layer of particle board in the front and back. Center the bit horizontally 3/8" up from the underside of the counter. Drill your holes 1" deep. This is where the spring clip on your sink bolts will grab. You can test that the clips will fit then put a small beed of clear siliconized acrilic latex calk around the edge of the sink and install. Wipe up any extra squeeze out with a wet rag and then tighten the bolts and clean up again.
Now you are ready to install the plumbing. If you are using a new garbage disposer with the dish washer draining into it there is a small plastic disc you have to knock out before the dish washer can drain into the disposal. That plug is there to seal the disposer if you don't have a dish washer.
Get more help if you do not understand all the instructions. If you are pretty handy with mechanical things you should be able to get this done. If you have a different kind of sink please specify that and get more help.
3helpful
2answers
We cannot get the mounting clips to stay on
I have spent several hours trying to solve the same problem with a Franke Granite double basin sink. The clips for this Franke sink appear to be a piece of engineering garbage, and the instructions are utterly useless - A huge piece of paper with a template, and tiny pictures that look like they were drawn by a kindergartner with a crayon. The instructions for using the clips --oh there are none - other than a blurry picture in which the clips could fit inside this period (.). Lots of other people appear to have the same issue. I like the Franke sink, but without proper mounting hardware, this franke sink is no better than the poorly made clips, and the Franke Sink horrible instructions that it came with.
What is the recommended sink mounting clip for a 22x33 sterling by kohler self rimming kitchen sink. I had purchased elkay "u" clips it does not appear that they will work.
Technically, you are suppose to have the clips holding the sink down. However, that is a pretty heavy sink you have. If you apply a clear tub/shower adhesive caulk around the opening for the sink, it will prevent the sink from shifting on you. Sometimes, as an added precaution, I will apply a second coat from underneath the sink after the first application has had time to cure. You will not have any problems in taking this approach to solve your problem. However, if you feel you absolutely need the clips, you can call Kohler to inform them that your sink did not come with these clips. It has been my experience that they will ship the clips out to you at n/c. Hope this helps.
How do i install them?
First do a dry fit to make sure it fits in hole properly then put a bead of clear silicone on the countertop around the cut out edge lay sink in hloe and install the mounting clips do not overtighten mounting clips they only need to be snug clean excess silicone with a rag.I suggest installing faucet and basket strainers first on sink before installing makes job easier
How do the clips go on 3/4 granite 3/4 plywood
You might have to route out the wood where you want to put the clips because the clip hardware is not intended for a top thickness greater than about 3/4 inch
I have many scratches on my kohler stainless sink.how do I remove them?
You would use rubbing compound -- same kind of stuff as used on autos -- there are different grits -- super fine on up, just like sandpaper. It'll tak a lot of rubbing. Probably good do a reasonable job with a buffer/etc. on a drill motor.
Sink won't fit cut out
You will either have to go with a different sink or contact a local granite dealer and they can send someone out that can enlarge the hole for you on site.
Apr 05, 2009 • Home
1helpful
Installing stainless steel sink with metal clips
if you look at edge of sink you will see small rail the bulbous end of clip goes in rail and flat side of clip goes against under side of countertop you then tighten clip which will pull sink and counter together you should install with plumbers putty around rim
9 month old sink cracked, need to install new undercounter Kohler with clips. How hard is installation?
Not difficult. You can make it even easier by purchasing the undermount sink installation kit from Kohler. Good luck
Top Kohler Plumbing Experts
Paul Carew
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
