Washing Machines Logo
Natasha oosthuizen Posted on Jun 23, 2019
Di I need to connect a warm and cold tap on my toploader only have a hot tap connected is that why it only taps water while in wash mode but as soon as it goes into rinse mode it does not tap watwr
Eric Gundersen
Level 1:
Habit-Forming:
New Friend:
  • Contributor 20 Answers
  • Posted on Jun 24, 2019
Eric Gundersen
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
20
Questions
0
Helped
11106
Points
51
Rinse cycle needs cold water .Seperate water valve
4 Related Answers
john mc donald
  • 121 Answers
  • Posted on Mar 03, 2008
SOURCE: Washer/Dryer
it depends if you have a combie boiler if not should be cool but if so would recomend a screw on tap connector from any good hardware store for your cold pipe
Anonymous
  • 1430 Answers
  • Posted on Jul 21, 2010
SOURCE: Hi there, I just bought a second hand hot point
no problem at all using only cold. Most washers only will fill with hot water after that all other cycles use cold.
Testimonial: "great. thankyou"
Anonymous
  • Posted on Nov 19, 2011
SOURCE: No hot water getting into Estate topload washer.
I have an WTW4400 that will not let any hot in,The tech changed the temp sensor and it worked for a month or so and the same problem is back..Screens are ok..Jim.
elisa_ashley
Elisa Ashley
  • Posted on Sep 21, 2012
SOURCE: I have a kenmore elite H3 washer. The cold water
Check the inlet valve solenoid wires for resistance with an ohms meter. The cold and hot solenoids should have close to the same resistance. My washer had a weak solenoid causing the hot water valve to close after 4 or 5 seconds. While checking the solenoid wires for resistance with the ohms meter, I noticed the cold side had 51 ohms but the hot side only 8 ohms. Hope this helps.
I have a whirlpool he washing machine, when I put the temperature on warm or hot, all I get is cold water. what can I do?
Hi Kimberly, You have to have both hot and cold water taps connected and turned on and if you have then your hot/cold water switch is faulty, I hope this helps........CHEERS..
When water is on mains the hot water doesn't work only the cold working
If you have hot or warm wash selected and you get no hot water, a possible cause is that the solenoid inlet valve on the hot connection has failed. Try connecting the hot tap to the cold inlet on the back of the machine, and selecting cold wash. If you then get hot water coming in you will know it is almost certainly the solenoid inlet valve on the hot connection.
2answers
No hot water getting into Estate topload washer. Have to turn off cold tap completely to get hot washer for wash cycle. Then turn cold tap back on for rinse cycle.
One simple thing to try is to clean them screens on the water valve. Remove the hoses and get the screens out. Give em a clean or chunk em and wash on!
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
When i try and start the washer it hums it won't fill it spins just won't fill
Hi and welcome to FixYa, I am Kelly
Turn off the water at the wall connection remove the hoses noting the positons of HOT and COLD. Then clean the inlet screens in the water valve. (lift out by using a knife blade on the outside of the screen) Wash the screens by rubbing your fingers ofer them under slow running water then reinstall them.
Before you start try a hot wash.. and then cold wash to see if either has water coming into the machine. If it works there is a way to back flush the water valve using a warm water wash. You remove one hose and stick it in a bucket. Turn ON the other hose and let water flow into the bucket while gentily tapping on the hose connection with a screw driver HANDLE. Reverse hose connections and repeat hose in bucket and tapping on hose connection. Reconnect both hoses then try HOT and COLD wash fill cycles. Let me know what happened.
Thanks for choosing FixYa,
Kelly
Servis model M3905W does it matter if the hot and cold water are connected up the right way round and if so what isthe right way round?! Thanks
Makes a big difference. Cold water valve is is normally marked blue or simply cold water. connected to cold water tap. Hot water marked with red colour or simply hot and connected to hot water tap.(Red hose - Hot water. Blue hose- cold water.).
No cold water is comming out of the cold water pipe, when I press warm/cold only the warm water comes out what could be the problem?
hi sounds like u could have self pluming taps on your hot cold pipes common for them to get blockd due 2 hard water need 2 replace taps or remove and clean holes out in old taps hope im right from washerman27
DISWASHER hdw100wht
You could if you wanted a hot wash. You cannot dry without cold water. The dryer cycle requires cold water to draw moisture out of the clothes.
You can create a custom program that has no dry cycle. I usually do the laundry this way and hang dry, however I only have cold water hooked up.
You could get cold from the cold tap by installing a few outdoor hose quick connect parts to the tap if your faucet ends in a screw fitting. You may also need screw on expander for this to work. Go to you local hardware store and tell them you want to get the outdoor hose quick connect parts and an expander to fit on your household tap. Buy metal parts NOT cheapo plastic.
Not able to do hot washing
My LG Toploader (wft753a) has a cold and a hot inlet, and the mechanism inside the machine simply turns the flow from each tap on and off. There is no internal heating element in it.
Top Washing Machines Experts
john h
