HELPPP!! i deleted the connection settings be mistake
I was trying to get connected to internet and i have already tried doing the settings before, but then i thought clicking on "clear settings" would just erase the codes i put in but it realy erased the connection settings so i can never use them again. i want to know how i could get the connection settings back by reseting the console but not loosing my game data. do i click on Format Wii System Memory? will that loose all my game data??? :( please helppp
Re: HELPPP!! i deleted the connection settings be mistake
Yes,you will lose all of your games,but you can always copy them to a sd card or memory card.formatting the wii will take it back to the factory settings.
your lumia 800 is ok and working fine. there is problem with your internet connection or your wifi modem. your modem's internet setting may have been altered by someone by mistake. your pppoe user name and password may have been deleted. when you will connect wifi to your lumia, then sometimes it will automatically start internet connectivity test. if this test passes then your internet will work fine, if it loses then you cannot use internet.
Hi
If you deleted the internet channel then you have to download it again. 1.Go to the wii shop and download again (should be free) if you've already payed for it before.2.If you deleted your connection, just go to the options menu and set it up again Hope this helps
1. Delete the configured wireless connection/s if you already have one.
2. Enable wi-fi but do not perform search at the moment
3. Now open the browser and select settings then browser profiles press search for wi-fi.
4. Select the connection that you want to connect to then type the details and match the settings on the router.
5. Auth type = WPA, encryption = TKIP, network key = router pre-shared key, protocol = HTTP, Home URL = address of modem (you can change it later if everything is already working), leave proxy blank, linger = default, adhoc = off, no need to do advance settings.
6. Save the settings and do not connect yet.
7. Exit the browser and go to Wi-Fi and select the connection that you have just configured and select details.
8. Check all the settings if ok. if the channel is different with the router, adjust it on the router to match the one used by the phone. IP address = not connected (it will automatically connect once you browse the internet).
9. Now, try to browse the internet but you must set first the connection you've just configured as default connection.
hope rhis will be helpfull to you.
Please rates me.
goodluck.............
HiI'm guessing you have the network preferences set to use PPP for you internet connection.Turn PPP off and delete it from the list.. Set the preference to TCP/IP and try again.
have one.
That's it. I hope that this helps. This applies only to personal
wireless network.
Please try these instructions:
Wireless router side
1. Set wireless mode to B-G Mixed
2. Standard Channel = 8
3. Encryption - TKIP
Phone side
That's it. I hope that this helps. This applies only to personal wireless network.
