SOURCE: one handle kitchen faucet leaks
There are "o" rings in the area where it is leaking. You can get them at almost every hardware chain. Clean everything well with scotchbrite ant put silicon grease on before you put it back together.
SOURCE: The kitchen sink makes a loud popping noise
Try removing the aerator on the faucet. If that resolves the popping sound, try replacing it with one that allows for a higher flow of water. (Also the existing aerator may be clogged).
SOURCE: faucet is leaking from the cold water line inside
Hello
First shut off water to faucet.There should be a allen screw that holds the faucet together near the top back of the handle,lossen this and pull top off.
Next take some pliers and tighten down the lock nuts to compress the washers,do this gently.
Reassemble,water should stop leaking.
SOURCE: can't get the replacement hose through kitchen faucet
you will need to undo the tap from the sink pull the tap up a little and feed the hose through the hole and connect it to the tap then re fix the tap to the sink most pull out taps are painfull to change the hoses
SOURCE: I just installed anew american standard single
The noise you are hearing is know as water hammer....it is a result of the sudden change in pressure in the piping....it is not cause for concern just a pain in the rear...
You could replace the faucet, but many of the newr ones for some reason do that...the other way to fix it is to have a water hammer arrestor installed in the piping...
heatman101
