Question about Kenmore Freezers
Kenmoore upright freezer cold but not freezing
Kenmoore upright freezer model 253.9264211 '97 over last month freezer temp dropping. Now have turned all the way up and cold but not freezing. any suggestions to fix?
    Brigadier General:
  • 8,619 Answers
Hi!
Thanks for using FixYa. First of all please check that there is air flow in the upper vent baffle in the fridge section which is located behind the crispers. If there is no air flow at the vent baffle in the upper fridge section then this is the cause of the issue you’re facing with. The evaporator fan pushes the air through ducting into the refrigerator from the freezer and if there is any material obstructing it then clear it.
If still the problem persists then you need to check the following things:
The defrost circuit contains defrost timer, defrost heater(s) and defrost thermostat. Defrost timer failure will not put power to the circuit. Defrost heater failure will fail to defrost when the timer applies power. Defrost thermostat must be closed for defrost to take place. First locate the timer, rotate the clutch head screw clockwise slowly until one distinct click is heard. Now the timer will be set in defrost mode and defrost should complete within 30 minutes or less after which the refrigeration should start cooling again. If defrost takes place and it does not go back to cooling automatically turn the screw once again until you hear the second click, unit will start. Replace the timer. If defrost does not take place in the time frame above and the unit restarts in cooling test the defrost heaters. From the heater(s) follow the wires from each end to where they plug into the circuit. Unplug them and test through the heaters with an ohm meter. You should get a reading if they are good, if no reading then you need to replace the heater(s). If you get a reading on the heater(s) then you need to replace the defrost thermostat.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Aug 14, 2009
6ya staff
SOURCE:
Frigidaire twin freezer not working
Check the freezer back wall for snow or frost.If it's there you have a defrost problem.
May 25, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
The alarm button is flashing
-18c is about 0 F. it shold be cold enough to freeze you know what.
you might want to turn the tempture up a little.
Apr 01, 2009 | Bosch 9.1 cu. ft. / 258 liter Upright...
Freezer compressor runs steady & getting -30F
You probably have a defective thermostat or sensor for reading the temperature.
Mar 23, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer Not Freezing Food
there is a circulation fan and also a vent. Either the fan is blowing, or there is a cloged vent.
Feb 11, 2009 | Kenmore 14.1 cu. ft. / 399 liter Upright...
GE upright freezer
If this is a frost free model the fan could be bad. If not frost free it is probably low on freon. I don't recomment fixing this as you can never really trust the freezer again. Most of the time the leak can't be found and adding freon is only a temp solution.
Jun 24, 2008 | GE 16.7 cu. ft. / 473 liter Upright...
Kenmore Upright Freezer Model 253-9280810
is it possible the door has not been closed at some point?
If so they can build up with ice in the evaporator which the defrost system cannot handle....Try a manual defrost.
Depending on where the unit is installed high ambient temperature can drop the internal temp enough to set the alarm off though they will still freeze sufficiently
Dec 28, 2007 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Not Freezing, but cold
The thermostat should be a close circuit when requesting cold temps. or when asking the compressor to come on. The exterior surface on some freezers warm when asking for cold inside. Yours has a condenser coil on the back and that should warm when cooling. If compressor is runningit should be wrm if no freon has leaked from freezer somewhere.
The defrost timer should rotate clockwise during the day and give approx. 3 defrost daily or about every 8 hours. Until the thermostat is resolved and asks for a closed circuit the compressor will not come on. Unplug freezer from outlet,remove thermostat wires, then turn the thermostat to its coldest setting and check again. If no closed circuit the thermostat will need replaced first. Hope this has helped you, Sea Breeze
Nov 01, 2007 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Kenmore Freezer Model 23041
I have an upright freezer which temp was unstable. The coils were frosted up, and the circulating fan was unable to pull air across the cooling fins.I defrosted the unit, cleaned it up, and turned it back on. Worked fine until it frosted up again. The unit was a no frost model. I had to have it serviced, and one of the defrost sensors was bad. No problems since this was fixed.
Aug 13, 2007 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Freezers Logo
280 people viewed this question
Top Kenmore Freezers Experts
John Tripp
John Tripp
Felizardo Erilla
Felizardo Erilla
PNiss
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
