Yes, it should be HD ready. There should be a small label on the front of the TV if so (provided it has not been removed). You will need a HD cable box, convertor or HD satellite box (Direct TV or Dish Network) to view HD broadcasts (even from free over-the-air HD broadcasts if you live within range of a local broadcasting station). I had the same, or very similar TV but upgraded to flat screen plasma set.
Hi, Your TV is set for HD but you will need a set top box. (PVR) You will need a digital decoder to recieve HD or digital channels. Talk to your cable or dish companies for more info. Good luck.
HDMI Tv's have a HDMI input and connect that the to the HDMI input on back of HD Sky box if not HD ready TV you'll have either 1 or 2 F-Connectors which go from Dish to input points1 and 2 on the back of the sky box then Scart lead from box to TV -
If you are using a powerstrip may not be supplying enough power to run the LG HDTV and your HD receiver. If you are using a powerstrip make sure the receiver is plugged directly into the wall. Otherwise this may be a grounding issue please reply if this doesn't work and we can look into some other possibilities. Daniel Busa DISH Network Customer Service
You need a HD box connected to the DTV input on the back of the set (it is marked 1080) This set has only one HD input for this---HD ready means it will work only with a box (some newer sets have a HD tuner built into them and for basic HD channels do not need a box).
I am not absolutely positive, but I do not think you will be able to get ANY TV after the transition without a converter box, unless you hook up to cable or a dish. IF your Tv were able to get HD, it would say so on the set...
I live w/ a son & DIL and we have Direct TV so we can already get HD programs, but since none of our sets are High DEF we do not get them IN high Def.... I also have two small TVs,- one in the spare bedroom and one in my computer/ library... both of those are hooked up with old fashioned antannae..[ I also have a VCR hooked up to each]. I have added a converter box to each and can already get more stations than I did before and the picture is better,
although it is NOT in High Definition; You have to have a High Definition TV to get programs in that foremat, although you can get a GOOD program; so it was worth the small amount I paid for the boxes... I got the Government discount coupons so they were reasonable...
Last week one of the local 'Best Buy' stores advertised the converter boxes for as low as $9.99 w/ the coupon... I think the Gov'mt has run out of funds, however.
Dish remotes generally will not program to combo units. There are a few exceptions but if you have already performed a power scan and have not had sucess you have one of the units that will not work. Dish is introducing a new receiver called a 222k which has a learning remote to prevent these types of issues. The 222k is a HD dussl tuner NON dvr receiver.It also has an expansion port that will allow a external hard drive to be connected to it which will allow the receiver to behave as a DVR unit but with added benefits an internal DVR model lacks.
Hope this answered your question and thanks for using FIx Ya. Let me know if I can be of further assistance.
