I have 2 unregistered Telstra V580a handsets. How do I register them to the main base?I believe that I'm supposed to place the handset to the main base and hold the ''Page'' button down for 4 secs. However, when I do that nothing happens.
Same problem here T.T really urgent
Please have a look at this sitehttp://www.howtomendit.com/answers.php?i...
I tried many times without success until I found that I have to take the handset out of the base before pressing the "page" button. It took me half an hour to work out this!
I have spent a day trying to register my 3 handsets. Eventually I did it!
1.Switch off base station
2.Wait for handset screen to display "connecting"
3.Press and hold menu key on handset
4.Select yes to remove registration
5.Follow the above for ALL handsets you want to use (I have 4)
6.ALL handsets will display Not registered
NOW IS A TRICKY PART
1.Switch on base station and place handset in holder
2.Wait for Message on LCD asking to press page button
3.Press and HOLD page button on handset until IN USE button is blinking
4.Release Page button and press it again - you will hear the beap - your handset is reset
5.Do the above for your other handsets
Now do actual registration:
1. Place the handset you want to be #1 on the base and press Page for 4 sec - the message connecting ... should come and the handset will register as # 1
2. Do not remove the battery from registered handset
3. Place the handset you want to be # 2 on the base and press Page for 4 sec - will register it as handset # 2
4. Do not remove the battery from registered handsets #1 and 2
5. Follow the steps with the other handsets you have
All handsets are registered and ready to be used
