Question about Ryobi Drills
RYOBI 40V BATTERY DATE CODE LOCATION? - Ryobi Drills
2 Suggested Answers
6ya staff
SOURCE:
rgall3285
ray gallant
  • 64733 Answers
SOURCE: how do I adjust the length of the shaft on a Ryobi ry40001a 40v line trimmer?
perhaps reading they manual explains that feature
mine has a nut that you loosen then slide it longer or shorter and retighten the plastic nut .
Posted on May 24, 2015
Ryobi 40V 2.6A battery. When I put it on the charger the charger blinks green for about 10 minutes and then goes to solid green. However, after 5 minutes of use my Ryobi trimmer dies. I repeat the...
From your description the battery is probably faulty. If the batteries are still quite young it is possibly just one cell and while Ryobi don't refurbish batteries there are companies dotted around that do.
If it is a nicad battery, Ryobi told me just a couple of days ago they no longer supply nicad replacements and expect everyone to upgrade to lithium, which means also buying a charger.
Aug 19, 2018 | Ryobi Drills
40V 24 inch ryobi hedge trimmer switch not working
You are sure about the battery have it tested
Jun 04, 2018 | The Computers & Internet
My 40v Ryobi battery will not charge. The charge shows a flat red light that sometimes blinks. The battery shows as charged. It will not work.
Check the battery with your multimeter. If it reads below 36 volts (or whatever the cutoff point is) it may be damaged. But before you run off and buy a new one, use the multimeter to check the voltage from the charger.
Or borrow a good battery and see how your charger behaves.
that way, you can identify the cause of the problem
Mar 12, 2017 | Ryobi Drills
Ryobi 40022 trimmer (40v lithium battery) has completely stopped working. Battery and charger kept inside when not in use. Battery indicates that it is fully charged when in the charger. Any ideas?
Sounds like a bad charger my friend..test suposly charged battery with a multimeter and you will find your answer...can also test charging unit with it too...GL
Aug 13, 2016 | Ryobi Garden
Ryobi 40v trimmer stops working with 1/2 charge left on battery
Battery is weak. Those lights are really useless...more a marketing gimmick. It almost sounds like it developed a memory...this happens when certain types of batteries are not fully discharged before being placed on the charger. Replace the battery and make sure to follow charging directions for that particular type of battery
Aug 08, 2016 | Ryobi 40-Volt Lithium-Ion Cordless String...
Fuel mixture ratio for Ryobi SS300 weed eater
Are you sure about the model number? I see several 30CC engine string trimmers by Ryobi. Two are the Ryobi RY30040B (SS30) and a RY30544 (SS30).
For both of these models, mix a high quality 2-cycle engine oil at 2.6 oz. per gallon of gasoline to pour into the gas tank. This ratio is used in several other Ryobi string trimmer models. Many Ryobi product manuals are available here: https://www.ryobitools.com/power-tools/support/manuals . Most Ryobi gas powered and 40V battery-powered tools will have a model number that starts with RY. The 18 V battery powered models often start with a P.
I hope this helps. If you add a comment with the actual model number, I may be able to provide more information.
May 20, 2016 | Ryobi Garden
Drills Logo
97 people viewed this question
Top Ryobi Drills Experts
JOHN LAPIER
roeb
Are you a Ryobi Drill Expert? Answer questions, earn points and help others
