Wireless connection was working fine now I can not get it to connect. what should I check? Thanks
Look for a switch that turns on the wireless device. Also check in the connection manager if the device is active and the wireless adapter is within range.
Also try redownload and install the driver from dell
1. Try connecting on another PC. If you connect then next.....
2. Check the wireless card or network adapter in the properties. There should be a "repair connection screen that will popup click "repair connection"
this will check the connection to the wireless card and cause a ipconfig release and renew connection. next if this doesn't work
3. check your network id see if you mistyped the password that is if you have WEP enabled.
4. check if bluetooth or cell phone is interfering with the connection
5.check the wireless router to see if it is pluggen in properly.
6. Disconnect router for a minute then plug power to again and try the connection.
7. Call the ISP (internet service provider) to check their side of the connection and verify connection.
also try redownload and install the driver from dell
