Using Windows® Media Player 10
1. Start Windows Media Player 10 and connect the unit to
your computer. On your player’s display it should say
‘MTP’. If not, then while the unit is connected press the ‘M’
(mode) button to change from ‘USB’ to ‘MTP’ mode.
2. If you have not set up synchronization between your computer
and this device, the Device Setup Wizard starts. In the
Device Setup Wizard, select Manual.
3. Click Finish.
4. Select Library option. On the right pane select Sync List.
5. From the left pane you can select the Play list or Library
and you will see the content songs in the center pane.
6. Select the songs from the center pane, drag and add them to
the Sync List.
7. Click the ‘Start Sync’ button in the Sync List pane.
8. Repeat steps 4-7 for any other items that you want to copy
to your unit.
If you normally create a profile for your GPX on your desktop computer. Delete that profile, and then add back your GPX to your computer via the cable and it should work. I presume you are using windows XP?
