Question about Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger
WEED EATER STRING
I HAVE A GAS WEED EATER FROM SEARS AND THE STRING WILL NOT STAY LOCKED. AS SOON AS THE WEED EATER IS TURNED AND YOU BEGIN TRIMMING IT JUST COMES OUT.
  • 3,600 Answers
You have the string in backwards, or the gear is not ingauged.
Posted on Aug 13, 2009
6ya staff
SOURCE:
Weed eater runs fine till I tilt it down to start trimming then it dies??
Check the gas line that is in the fuel tank . It has a filter on it and if its not down at the bottom of the tank where it should be then its not getting the gas it needs. If you tip it the gas may be too low for the hose to pick up. The hose needs to be on the bottom.
Jul 14, 2016 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
My weed eater (toro), won't let me pull the cord at all. This weed eater doesn't take oil I don't think.
All internal combustion engines use oil of some description. I take it this is a 2 cycle engine and you have not added oil to the gas. If this is the case the engine is locked up, and must be replaced. Sorry.
Mar 25, 2012 | Toro& Electric String Trimmer
Weed eater starts but won't stay running
just bought a new Poulan 25cc 2cycle gas power weed eater . I can start it with the choke on but as soon as put on run it dies.
Jul 08, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Need to add new string to a weed eater xt 12
    For manual go to;
    http://www.poulanpro.com/poulanpro/manualSearchPrepare.do;jsessionid=332BA6FC1EA2792C79A0A463204716AA
    Preparation Instructions
  1. Press the lock and rotate the spool counter-clockwise.
  2. Remove the locking ring if your weed eater has one.
  3. Take off the automatic feed button.
  4. Wipe away any debris.
  5. Push down on the spool to release the locking tabs.
  6. Remove the spool from the chamber. Restringing the Weed Eater
  7. Feed the line into the lower deck, traveling the line in an upside down J fashion (almost like sewing on a button but do not tie off the line). This secures the internal end of the line.
  8. Wrap the line following the directed arrows. Do this until it wraps to the depth of the chamber.
  9. Secure each of the lines into its own upper and lower deck grove settings.
  10. Install the spool back into its chamber.
  11. Pass the lines into the left and right holes and snap the spool into place.
  12. Once the spool is in its sleeve and fed into its left and right eye holes, pull both ends simultaneously.
  13. Reinstall the locking ring if necessary.
Do it yourself repair: common repairs for a weed eater Amazingly, weed eaters are one of the simplest yard tools to take care of. One of the first things you should do to keep your weed eater in good condition is to clean it. It is important not to clean your weed eater with water or gas, which may destroy the engine. The best, and easiest way to clean it is by blowing off dirt and grass with an air compressor or a leaf-blower after every use. The next most important thing to maintain on your weed eater is string. When the string gets low you can remove the lower part of the head (the part that the string comes out of) by pushing in slightly and turning the head counterclockwise. Cut the new string no shorter than 6 inches or the weed eater will not advance the string properly when in use. Thread the string back though the guides, making sure to follow the arrows on the guide. If the string is not put through the guides the right way, the head may pop off during use. Next, replace the bottom of the head by pushing and turning clockwise. You can totally skip this step by buying a string replacement cartridge. Though it is much more expensive, it saves you the trouble of having to restring your weed eater yourself. window.google_render_ad(); If you find that the head of your weed eater is worn on bottom or hard to get off to replace the string then it is time to replace it. This can be done very simply by unscrewing the two screws at the top of the head and slipping it off. Then, just slide the new one on and tighten the screws. After a few months of use, you may find that your weed eater is losing power or that it is making a strange lower pitched noise. This may be caused by a dirty filter. To check, unscrew the knob or wing nut on the carburetor. Inside you will find a small square screen, this is the filter. If the filter is gray or black then it is time for it to be cleaned. The easiest way to clean it is to blow it out with an air compressor. It can also be washed with plain water, but you must let it dry before placing it back into the carburetor. Once the filter is white or only light grey it is ready to use again. Always make sure to mix the gas and two-cycle oil in the proportions that are listed in the weed eater’s manual. Never use anything but two-cycle oil, normal car oil will not work and will damage your engine.
Jun 01, 2009 | Garden
Black and decker grass hog electric weed eater won't feed string
I bought the electric grasshog trimmer. Worst investment I ever made on Garden supplies. The line is completely gong within ten feet of trimming. I've used it four times and gone through twenty spools. In the trash now.
Apr 22, 2009 | Black & Decker 14" Grass Hog Xp...
Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger Logo
701 people viewed this question
Top Poulan Garden Experts
roeb
dannydoesita
Marvin
Marvin
Are you a Poulan Garden Expert? Answer questions, earn points and help others
