Jump onto www.toro.com and download the free service manual for your machine. Note down all the details on the ID plate on the mower, you will need it to find the correct manual......
From there you can get the part number. Good Luck!
SOURCE: Toro 6.5 hp 9 year old mower. Starts Ok; surges
Sounds like your carburetor needs to be cleaned out. The surging is usually a sign of running to lean (not getting enough gas) because of possible water, rust, gum, varnish or trash in your carb. Hope that helps.....
SOURCE: How can I detemine type of stator in my mower without disassembly
If you have two wires coming from under engine shroud, a black and red, plugged into a connector with a white and black wire going to the mower, It's a Dual Circuit alternator.
SOURCE: Toro electric start won't start manually
If it doesnt start manually,you have another issue to deal with. Whether it has electric start or not you should be able to manually pull start it. You can also get the model and serial number off the engine and contact your nearest toro dealer to have charger and key ordered. As far as a push button,it can be done,just a matter of finding someone to install one for you.
SOURCE: how to replace drive belt on self propelled toro commercial push mower
the should be a plastic cover under the engine
