All my discs are scratched how do i fix discs at home
Most Game Discs, DVD’s and CD’s can be fixed quite easily back to “As Good As New Condition”. Some home remedies or cheap repair kits may help with some light marks or very light scratches on some discs and you can pick these repair kits up in some stores or online rather cheaply, but a professional disc repair service is usually required to repair any discs with anything more than very light scratches. If the discs have any decent scratches on them, your probabaly better off sending them off to a proper disc service rather than spending money on a home repair kit only to find out that they wont fix most the discs.
For further help on disc repairs, visit:
www.discREPAIR.ie Get Scratched Discs Repaired Back to "As Good As New Condition".
Check the “More Info” & “FAQ” Sections for further details on game disc repairs and related matters.
If you tried some home remedies and they have not worked, try sending the disc off for repair. Contact the site above for advice on repair and shipping.
Hope this Helps!!!
Purchase a CD scratch removal kit from a store or garage sale. You will have a very hard time getting the scratches out smoothly without the machine.
SOURCE: had ps1 game resurfaced, no longer works on ps2
Sounds like you need to get your money back ..the resurfaceing can also do more bad than good
But a little trick lightly rub a crayon over the disk ,,old pantyhose works great rub it off from center out then try your disk ,,have saved many good games that way
SOURCE: My ps2 Cant read my disc!
clean the disk with disk cleaner clean the lens of your ps2 with a cd cleaner meaning a cd with brushes on the other side of it or with some rubbing alcohol then it should let you read your games
SOURCE: PS3 will not read game, disc or BluRays.
Prob the BluRay lens, is it still under warranty???
Check to see if there are any scratches on the disc. Scratches or marks on discs will render game discs unplayable or will freeze the game and will often show a message stating "Disc Read Error" or something to that effect. With some scratched discs, the data cannot be read and the game console may not even recognize the discs at all, giving you error messages etc. Best remedy for starters, is to try clean the discs and make sure there are no smudges or dirt marks left on the play-side of the discs. If there are any scratches on the discs, they will need repairing.
Most Game Discs, DVD's and CD's can be fixed quite easily back to "As Good As New Condition". Some home remedies or cheap repair kits may help with some light marks or very light scratches on some discs, but a professional disc repair service is usually required to repair any discs with anything more than very light scratches.
Check the "More Info" & "FAQ" Sections for further details on game disc repairs and related matters.
Hope this Helps!!!
