W have a Whirpool commerical dryer at my hotel. Belt slipped off tumbler, and the tensioner came off unit. Have the dryer opened up, but can not find where to put tensioner back on at. And how to reinstall the belt. I think the unit i have is a CEM2940? Please let me know where to go from here. Also, a secmatic of the machine would help a great deal.
Here is the tensioner diagram you need, for most any dryer.
http://www.applianceaid.com/images/belt-config.JPG
First clean and lubricate the axel of the wheel with some spray silicone. Try not to get it on the wheel outer surface.
Then locate the slot in the bottom of the cabinet floor. The wheel should line up with the drive wheel at the end of the motor shaft.
Place the tang of the tensioner in the slot.
Press the wheel wayyy back passing a loop of the belt BELOW the tensioner wheel and loop it over the end of the small drive wheel.
Release tension on the tensioner and the wheel will pull it taught.
Unplug your dryer from the electrical outlet. Remove the lint trap by lifting its cover and sliding it out. Use a screwdriver to unscrew the two screws that hold in the housing of the lint trap.Lift up the top panel of the dryer and take off the holder for the door switch wire. Look for the screws that hold in the front panel of the dryer, located on top of the front panel, and unscrew them. Take the panel off the dryer by lifting it off.Look inside the dryer, find the broken dryer belt, and before taking it off, note the way it is routed around the pulleys, then take it off. Install a new Whirlpool dryer belt by slipping it around the tumbler with the grooves facing the surface of the tumbler. Ask an assistant to hold up the tumbler while you move the belt into the proper place, aligned with the black line around the width of the tumbler.Wrap the new dryer belt around the pulleys as noted in Step 3. If you don't remember how, or the old belt was snapped and not aligned properly, look at the dryer belt diagram in your user's manual.Align the front panel of the dryer with the tumbler. Put back in the two screws that hold the panel in place. Open the door of your dryer and with your hand, turn the spinner one time counterclockwise. Reconnect the holder for the door switch wire, being careful that it doesn't touch any moving parts.Use the screwdriver to carefully position the rubber seal along the back of the tumbler. Make sure the seal is on the outside of the tumbler and that none of it sticks to the inside of the tumbler.Slide the lint filter and housing back into place, and screw in the two screws that hold it in. Plug the cord of the dryer back into the electrical outlet and check that it spins properly.
