SOURCE: restiction code or factory set code for NOKIA 6233
ALL NOKIA PHONE CAPABILTIY TO ACCEPT ALL BRANDS OF SIMS SO THERE IS SETTING ROBLEMS IN UR PHONE factory setting UR PHONE WILL HELP U IF ITS NUTS SOLVE IT THAN
REMOVE MMC BACK UP OF ALL UR DATA FROM PHONE MEMORY INSTALL NOKIA PC SUITE IN UR PC AND DOWNLOAD UPDATES FOR NOKIA MOBILE FROM NOKIA.COM INSTALL IT AND UPDATE UR MOBILE ONLINE.IT WILL FORMATE UR MOBILE AND RESET UR CODE TO 12345 AND ALL SETTINGS
SOURCE: restriction codes for nokia 6233
HI
A restriction code is numeric code (password) that prevents a user from accessing certain technical settings of a phone. It is specifically designed to prevent a phone from being reprogrammed to work with a different carrier (service provider).
This is what is usually meant when a phone is referred to as "locked". There are also "unlocked" phones that can be reprogrammed to work with a different carrier.
The reason for this system is the way phones are often sold. Many phones are sold below cost, (at a loss to the carrier,) with the expectation that the money will be recouped in the cost of the monthly service plan. The up-front loss that is later recouped is called a Subsidy.
For this to work financially for the carrier, the user must not buy the phone and then use it with a different carrier. The MSL makes that nearly impossible.
Unlocked phones are ususally much more expensive than locked phones, because there is no subsidy to offset the cost.
You should ask the operator for the restriction code
SOURCE: what is the phone restricted code for NOKIA 6233
try this #pw+404767725207222+1
not solved yet then update your frimware
please leave me comment
